Getting wrong data from serial terminal using 18f2550 usb_cd
elcrcp
PostPosted: Fri Jan 27, 2017 4:23 am     Reply with quote
Hello guys,
I'm using sparkfun hx711 load cell amp and trying to read data from a load cell and then sending it to pc via USB. It looks like its working, it gets enumerated, I can connect and listen com port and get data but there is something wrong with incoming data and I cannot see why.
The data I send is 12 bytes in total, I should read |>XXXXXXXX<| but I get incorrect readings from terminal.
Can you help me please?
#define __USB_PIC_PERIF__ 1
#include <18F2550.h>
#device ADC=10
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HSPLL                    //High Speed PLL
#FUSES BROWNOUT                 // brownout reset BROWNOUT
#FUSES BORV21                   //Brownout reset at 2.0V
#FUSES PUT                      //Power Up Timer PUT
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES NOPBADEN                 //PORTB pins are configured as digital IO channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES MCLR                     //Master Clear pin enabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode) NOXINST
#FUSES PLL5                     //Divide By 5(20MHz oscillator input) PLL5
#FUSES CPUDIV1                  //No System Clock Postscaler
#FUSES USBDIV                   //USB clock source comes from PLL divide by 2
#FUSES VREGEN                   //USB voltage regulator enabled
#byte TRISB=0xF93               //TRISB register address for direct access
#use delay(clock=48000000)
#define PDSCK pin_b4
#define PDOUT pin_b0
#include <HX711.h>
#include <HX711.c>
#include <usb_cdc.h>
#include <STDLIB.h>
#define OK  1
#define NOK 0
   unsigned int32 loadvalue;
   TRISB=0x49;
   HX711_set_scale(1375);
   HX711_set_gain(128);
   HX711_tare(20);
   usb_init();
   while(!usb_cdc_connected());
   printf(usb_cdc_putc,"Usb READY\n\r");
         loadvalue=HX711_get_units(10);
         printf(usb_cdc_putc,"|");
         printf(usb_cdc_putc,">");
         printf(usb_cdc_putc,"%2X",make8(loadvalue,3));
         printf(usb_cdc_putc,"%2X",make8(loadvalue,2));
         printf(usb_cdc_putc,"%2X",make8(loadvalue,1));
         printf(usb_cdc_putc,"%2X",make8(loadvalue,0));
         printf(usb_cdc_putc,"<");
         printf(usb_cdc_putc,"|\n\r");
         HX711_power_down();
         HX711_power_up();
   }// End While
}// End Main
And these are data I read from terminal:
|>00000001<|
|>0000000001<|
|>00000001<|
|>00000001<|
|>000000001<|
|>00000001<|
|>000>00000001<|
|>00000001<|
|>000000000001<|
|>000>00000001<||
|>>0000000001<|
|>00000001<|
|>00000001<|
|>000>000000011<|
|>00000001<|
|>000000001<|
|>000>00000001<|
|>000000001<|
|>00000001<|
|>002>002FA997<|
|>002F>002FA988<|
|>002FFA992<|
|>002FA98CC<|
|>000000003<|
|>002FA9999<|
|>00000000<|
|>00000001<|
|>00000004<|
|>002FA999<|
|>002FA99B<|
|>000000002<|
|>00000009<|
do you have an idea about why this is happening?
There is nothing you can't do if you try
PostPosted: Fri Jan 27, 2017 6:14 am     Reply with quote
Overall, you need to isolate where the problem is
Step one...
I'd simplify your code. Just have the PIC send a KNOWN stream of data to the PC,something like |>12345678<| . Do this several times for various KNOWN data. Don't always use the same data. If this works then you KNOW it's not the communcation of the data, rather the data itself that is 'bad'.
As to 'bad' data...it can either be
a) a bad sensor( faulty ?)
b) incorrect driver for the sensor(timing,bits,??)
c) bad wiring /pcb traces
d) power supply( 5V PIC, 3V sensor )
e) something else....
Jay
PostPosted: Fri Jan 27, 2017 6:15 am     Reply with quote
You need to include usb_task in your loop.
Even if the USB system is being interrupt driven, this still handles the 'housekeeping' for USB, and must be called at reasonable intervals. Your half second may well be OK, but it does still need to be called....
elcrcp
PostPosted: Fri Jan 27, 2017 9:16 am     Reply with quote
Thanks for advice, I'll add usb_task Ttelmah. I tried random approaches and found the source of problem and it is somehow interesting =)
I was suspecting speed issues due to data amount I get. I was using USB3 port to connect PIC then I changed it to USB2 (or maybe 1.1 I'm not sure myself) then I started to get data correctly, 12byte data and new line.. all ok now.
I didn't write the hx711 driver codes myself but there were a few little corrections needed. I'll upload full codes after finishing tests.
PostPosted: Fri Jan 27, 2017 9:23 am     Reply with quote
USB3 ports, though they will behave as USB2, have drivers that generate faster edges on the waveforms. It is common for devices that have a slight impedance mismatch, to have problems when they are attached to USB3 ports, even when running in USB2 mode. Add two series resistors in the D+ and D- lines, adjacent to the chip. 22R each typically. These help to reduce the effects of any impedance mismatch (either in the PCB or in the chip itself), when fast edges appear.
PostPosted: Fri Jan 27, 2017 10:56 am     Reply with quote
comment: You should use USBView or similar PC program to 'look' at the USB port to confirm/deny HOW the PC has 'configured' it.
Magically 'some' program(ap) changed one I was using, one day, causing me no end of grief....
Jay
