Write/read float to internal DSPic30F eeprom - SOLVED!
younder
PostPosted: Sat Jan 21, 2017 10:47 am     Reply with quote
Hi Guys,
DSPic30F4012
Compiler V5.051
I'm trying to use the example available in the "C:\Program Files\PICC\Drivers\internal_eeprom.c" for Reading and writing a float32 to internal DSpic30F eeprom but It did not worked yet.
// Purpose:    Write a 32 bit floating point number to internal eeprom
// Inputs:     1) An eeprom address. Four eeprom locations will be used.
//             2) The floating point number to write to internal eeprom
// Outputs:    None
void write_eeprom_float(unsigned int16 address, float32 data)
   write_eeprom(address, &data, 4);
// Purpose:    Read a 32 bit floating point number from internal eeprom
// Inputs:     An eeprom address
// Outputs:    The floating point number read from the internal eeprom
float32 read_eeprom_float(unsigned int16 address)
   float32 data;
   read_eeprom(address, &data, 4);
   return(data);
//Totalizer_Km & Totalizer_L are Float Type
//*** Write ***
 write_eeprom_float(0x06, Totalizer_Km);  //0x06 & 0x07
      delay_ms(2);
 write_eeprom_float(0x08, Totalizer_L);   //0x08 & 0x09
      delay_ms(2);
//*** Read ***
Totalizer_Km=read_eeprom_float(0x06);
Totalizer_L=read_eeprom_float(0x08);
Any help would be very appreciated!
Hugo
Hugo Silva
PostPosted: Sat Jan 21, 2017 9:22 pm     Reply with quote
I don't have PCD so I can't test it. But if I did, the first thing I would do
is try addresses that have more separation between them. Just as a test:
write_eeprom_float(0x10, Totalizer_Km);
      delay_ms(2);
write_eeprom_float(0x20, Totalizer_L);
      delay_ms(2);
//*** Read ***
Totalizer_Km = read_eeprom_float(0x10);
Totalizer_L = read_eeprom_float(0x20);
Also, with the PCM and PCH compilers the compiler waits in a polling loop
until the write eeprom is done. No external delay is necessary. I suspect
the same thing is true for PCD.
I noticed that the function names you're using are different than what
I have in vs. 5.066 in internal_eeprom.c. I have the names shown below,
with the word 'eeprom' at the end:
void write_float_eeprom(INT_EEPROM_ADDRESS address, float32 data)
float32 read_float_eeprom(INT_EEPROM_ADDRESS address)
younder
PostPosted: Sun Jan 22, 2017 9:23 am     Reply with quote
Thanks PCM programmer! you hit the nail right in the head! It was my mistake... we need 4 bytes in the eeprom for storing a float variable... the data was overwriting 2 bytes - We can close this tread
Hugo Silva
