batonie
Programming Interface for TI DSP |
Posted: Fri Jan 20, 2017 1:35 am |
I'm about to design a PCB for a project with a TI DSP (TMS320C6720 datasheet).
What is the best method to use as an interface for getting the program onto the DSP? I haven't done this part myself before.
I'll be using CCS v4 and my motherboard has USB 2.0 pots and a parallel port but I'd rather use the USB so that I could keep using whatever cable I need to get in the future.
I'd prefer a low cost solution, I saw some JTAG emulators that cost 100's which is more expensive than I thought would be necessary, however it would be helpful to be able to debug when I'm programming. Thanks |
Posted: Fri Jan 20, 2017 2:12 am |
You are on the wrong forum.
This is for Custom Computer Services C for the PIC, not for Texas 'Code Composer Studio'.....
Texas run a Wiki here:
<http://processors.wiki.ti.com/index.php/Category:CCS>
Unfortunately Texas has took to using the name 'CCS' for this, long after CCS (the company).
So you need to join the right forum. |
batonie
Posted: Fri Jan 20, 2017 8:12 pm |
Ttelmah wrote: | You are on the wrong forum.
Fine, sorry for posting on the wrong forum, and thanks for your suggestion. |
