Display problem
art
Display problem
PostPosted: Tue Jan 17, 2017 2:55 am     Reply with quote
I'm trying to display a result " 1_0_1_0_ " from my code, but when I compile it, it shows message "Code has no effect" and display result is " 0_0_0_0_ "
Kindly please help. Here is my code:
#include <18F4550.h>
#fuses HSPLL,NOWDT,PROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <usb_cdc.h>
      char c;
      int8 i ;
      unsigned char d;
      unsigned char key;
   usb_init_cs();
   while (TRUE)
         usb_task();
            if (usb_cdc_kbhit())
                 c=usb_cdc_getc();
                 if (c=='\n') {putc('\r'); putc('\n');}
                 if (c=='\r') {putc('\r'); putc('\n');}
                 while(true)
                  ART:
                  d = usb_cdc_getc();
                         if(d=='R')   // push U for INPUT BUTTON
                                while (key!=32) // push SPACE BAR to stop
                                 if(usb_cdc_kbhit())
                                   {key=usb_cdc_getc();}
                                int16 a1,a2,a3,a4;
                                int b1,b2,b3,b4;
                               a1=10000;
                               a2=4000;
                               a3=9500;
                               a4=5000;
                              if (a1>=9000);
                                  b1=1;
                              if (a1<9000);
                                  b1=0;
                              if (a2>=9000);
                                  b2=1;
                              if (a2<9000);
                                 b2=0;
                              if (a3>=9000);
                                 b3=1;
                              if (a3<9000);
                                 b3=0;
                              if (a4>=9000);
                                 b4=1;
                              if (a4<9000);
                                 b4=0;
                             printf(usb_cdc_putc,"%u_%u_%u_%u_" b1,b2,b3,b4 );
                                   } key=0; // to initialize 'key' not as SPACE BAR
                     } // For USB format
               }       // For USB format
         }             // For USB format
}                      // For USB format
PostPosted: Tue Jan 17, 2017 6:05 am     Reply with quote
Look closely at this. What do you see at the end of the If lines?
                              if (a1>=9000);
                                  b1=1;
                              if (a1<9000);
                                  b1=0;
                              if (a2>=9000);
                                  b2=1;
                              if (a2<9000);
                                 b2=0;
                              if (a3>=9000);
                                 b3=1;
                              if (a3<9000);
                                 b3=0;
                              if (a4>=9000);
                                 b4=1;
                              if (a4<9000);
                                 b4=0;
art
PostPosted: Tue Jan 17, 2017 6:36 pm     Reply with quote
You are correct. Should not put " ;" at line if. Thank you very much
