PIC12F675 INT
ViperARG
PIC12F675 INT
PostPosted: Fri Jan 13, 2017 2:52 pm     Reply with quote
Hi dear friends =) !
I made this code for pic12f675 interrupt and I got it working but I don't know why when I press the button it won't initialize the interrupt until I switch it off. If I hold the pushbutton it won't trigger the interrupt until I leave it. Here is my code.
main.h
#include <12F675.h>
#device ADC=16
#use delay(internal=4MHz)
#use STANDARD_IO( A )
main.c
#include <main.h>
#use fast_io(a)
#INT_EXT
void  EXT_isr(void)
if ( !input(PIN_A2) == 1 ) {
output_high(PIN_A0);
delay_ms(3000);
output_low(PIN_A0);
 enable_interrupts(INT_EXT); // Habilita la interrupción en RB0
enable_interrupts(GLOBAL); // Habilitación general de interrupción
ext_int_edge(H_TO_L); // Config. int. por flanco descendente. (L_TO_H) para ascendente
input(PIN_A2);
set_tris_a(0x4);
     output_high(PIN_A5);
     delay_ms(200);
     output_low(PIN_A5);
     delay_ms(200);
     output_high(PIN_A4);
     delay_ms(200);
     output_low(PIN_A4);
     delay_ms(200);
PostPosted: Fri Jan 13, 2017 3:10 pm     Reply with quote
Does your button circuit look like this ? Or something else ?
In this circuit, when you press the button it puts Ground on the PIC pin.
When you don't press it, it has 5v on the pin.
           +5v
            > 4.7K
            <         ___  Switch
To          |        _|_|_
PIC -----------------o   o------
pin                            |
A2                            --- GND
ViperARG
PostPosted: Fri Jan 13, 2017 3:43 pm     Reply with quote
           +5v
            > 4.7K
            <         ___  Switch
To          |        _|_|_
pin                            |
A2                            --- GND
Mine was pull down with a 10k resistor, now I tried pull up and it works better, sometimes it miss, and I tried with cables and another switches and does the same thing, sometimes wont register the push... so weird.
PostPosted: Fri Jan 13, 2017 4:34 pm     Reply with quote
Since you have delays in the interrupt and in main(), you will be getting
the interrupts disabled warning. (Do you have compiler warnings
enabled ?). This means you won't get interrupts for the duration of each
delay statement in main(). Your program will seem somewhat unresponsive.
See this CCS faq article for a suggested fix:
http://www.ccsinfo.com/faq.php?page=delay_in_interrupt
It uses two #use delay() statements to generate separate delay routines
for the interrupt code and the code in main(). This removes the conflict.
