Timer1 and 67k22
curt2go
Timer1 and 67k22
PostPosted: Fri Jan 13, 2017 11:21 am     Reply with quote
I am either missing something in the documentation or just having an off day. I am using the SOSC to run the timer1 for a real time clock. I need the clock to keep running when in sleep(); I thought this was possible but it is not triggering the interrupt in sleep(); This is what I am using to initialise the Timer1. Any help would be great. Thanx guys.
Compiler verison is 5.056.
setup_timer_1(T1_EXTERNAL_SYNC|T1_DIV_BY_1 | T1_ENABLE_SOSC );
PostPosted: Fri Jan 13, 2017 11:35 am     Reply with quote
You NEED to post your program, not just one line ! We have NO idea if you've enabled the timer interrupt. That one line does NOT enable the timer1 interrupt capability of the PIC.
Jay
curt2go
Well this happens to me all the time. I post a question and then i look at what I posted, try a couple things and then i figure it out.
Problem solved. should not have had T1_EXTERNAL_SYNC just T1_EXTERNAL.
curt2go
PostPosted: Fri Jan 13, 2017 11:38 am     Reply with quote
Sorry I should have stated that the interrupt was working fine. Just not when i put the PIC to sleep. But I have it now.
PostPosted: Fri Jan 13, 2017 11:56 am     Reply with quote
Well done.
Makes sense if you think about it. Using 'sync', the clock is synchronised to transitions of the master oscillator. Asleep, this is off....
