Unknown device type -- Try PCH
rfjhh
PostPosted: Mon Dec 05, 2016 12:30 pm     Reply with quote
I'm using MPLAB 8.56 and I wrote this:
#include <18f4550.h>
#device adc=10
#use delay(clock = 8MHz)
#fuses INTRC, NOWDT, NOBROWNOUT, NOLVP
After compilation:
Error 24 "C:\Program Files (x86)\PICC\devices\18f4550.h" Line 2(9,19): Unknown device type -- Try PCH
In the 18f4550.h header file it's written:
//////// Standard Header file for the PIC18F4550 device ////////////////
device PIC18F4550
#nolist
//////// Program memory: 16384x16 Data RAM: 2048 Stack: 31
//////// I/O: 35 Analog Pins: 13
So, I think the right device is included....... I don't understand what happens.
PostPosted: Mon Dec 05, 2016 12:41 pm     Reply with quote
Go to the Configure / Select Device menu in the top right side of the
menu bar in MPLAB. What device is selected there ? It must be set
to 18F4550. You probably currently have it set to a 16F PIC.
rfjhh
PostPosted: Wed Dec 07, 2016 8:12 am     Reply with quote
Thanks, that's fixed. It works well.
