About the forum itself
Gabriel
PostPosted: Wed Oct 05, 2016 11:21 am     Reply with quote
Hi all,
Is there a way to Delete your own posts?
Id like to delete most of the comments i made on the MAX31855 driver page and replace them with one single comment and updated driver...
is this possible?
G.
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Wed Oct 05, 2016 12:30 pm     Reply with quote
1. Add your new consolidated post.
2. Edit your old posts to nothing.
3. Post a note in one of the "edited to nothing" posts requesting that
they be deleted.
PostPosted: Wed Oct 05, 2016 12:38 pm     Reply with quote
Since you're the 'author', you can edit them... hopefully CTRL A to select all, press 'delete' key ?
hmm.. couldn't be THAT simple, could it ??
Jay
Gabriel
PostPosted: Wed Oct 05, 2016 1:36 pm     Reply with quote
Mr. T I think you might have missunderstood what i meant to do.
I meant delete the post entirely not just the contents... this would probably result in a blank post yet not a "Deleted" post.
Ill take PCM_P's suggestion.
Thanks.
asmboy
PostPosted: Wed Oct 05, 2016 5:25 pm     Reply with quote
look at the original post
upper RH corner
see [Quote] [Edit] [x]
clicking [X] deletes the post and i think the thread if it is at the top -
try it
