Expecting a close paren ... why and what??
Jody
PostPosted: Fri Sep 23, 2016 4:31 am     Reply with quote
Oke get that error but why... made a small example:
At the first output_low(RS) I get the error..
If I replace it with: output_low(PIN_B0); it is fine... but I want the RS in it..
Compiler version: 5.025
main.c:
#include <main.h>
void CheckBusy(void)
   int1 busy_f;
   output_d(0xff);
   output_low(RS);  [b] <== THE ERROR[/b]
   output_high(RW);
   do
        output_high(E);
        busy_f = input(lcd_busy);
        output_low(E);
    }while(busy_f);
   while(true)
and main.h:
#include <18F8722.h>
#device ADC=16
#define   busy    PIN_D7;
#define   RS      PIN_B0;
#define   RW      PIN_B1;
#define   E      PIN_B2;
#define   CS1      PIN_B3;
#define   CS2      PIN_B4;
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES BBSIZ1K                  //1K words Boot Block size
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock=10000000,crystal=10MHz)
What is wrong???
PostPosted: Fri Sep 23, 2016 5:22 am     Reply with quote
Your problem is back at the defines.
First, move your #defines AFTER the FUSES. Fuses should always come right after the #device lines.
Second, remove the semi-colon at the end of each #define (see the manual)
Jody
PostPosted: Fri Sep 23, 2016 5:34 am     Reply with quote
yep that did it!!
semicolon remove was the trick thanks!!! :oops:
PostPosted: Fri Sep 23, 2016 7:08 am     Reply with quote
It's also a 'classic' CCS problem. Their syntax 'parser', will keep ploughing on and often fail several lines after the 'real error'. You can remove sections, or change the order that things are declared to 'narrow down' where the problem really is...
In this case though the first real error is in the line it displays on.
With the semi-colons there the error line gets translated to:
output_low(PIN_B0;);
Which has the first ';' being met before the bracket, so it complains that it needs a closing bracket.
