problem on sending string by using fputs
baris_akinci
PostPosted: Tue Sep 20, 2016 1:54 pm     Reply with quote
Hello, I need help to understand what is the main reason CCS C put extra value when I try to send string by using fputs via rs232 connection. the code belock is below
         char gonder[3];
         char gecici;
         char gonder[4];
         if (time <= 13) {    gecici='0';  }
         else                 {    gecici='1';  }
         gonder[0]=gecici;
         gonder[1]=sifre[2];     // entered pasword part -> 1
         gonder[2]=sifre[3];     // entered pasword part -> 4
         fputs(gonder);
I just want to see 114 instead of 114r. where this "r" comes from?? see the picture below. thanks in advance.
[IMG]
https://resmim.net/f/dhJlMv.png
[/IMG]
PostPosted: Tue Sep 20, 2016 2:13 pm     Reply with quote
You are lucky to only get an extra 'r'...
This is not anything special about CCS, but standard 'C'.
In 'C', a 'string' is a "null terminated array of characters". You are not adding the null terminator. fputs, will keep printing, until it sees such a terminator, so what you get 'extra' will depend on what happens to be in memory.....
You need to add:
gonder[3]='\0';
to terminate the array, before you try to print.
baris_akinci
PostPosted: Wed Sep 21, 2016 12:45 pm     Reply with quote
thank you so much Ttelmah. I have tried your advice and got the result well.
