PLL, INTRC_IO on PIC16F1847 SOLVED
gjs_rsdi
PostPosted: Sat Sep 17, 2016 3:52 am     Reply with quote
Hi
Trying to work with internal oscillator and PLL on PIC16F1847
CCS PCM C Compiler, Version 5.062, xxxxx
MPLAB v8.92
CCS fuses for PLL:
PLL_SW, 4X HW PLL disabled, 4X PLL enabled/disabled in software
PLL, 4X HW PLL enabled
In the data sheet:
The SPLLEN bit in the OSCCON register must be
set to enable the 4xPLL, or the PLLEN bit of the
Configuration Word 2 must be programmed to a ‘1’.
When using the PLLEN bit of the
Configuration Word 2, the 4xPLL cannot
be disabled by software and the 8 MHz
HFINTOSC option will no longer be
available.
Using external clock the below fuses configuration makes PLL Enable in MPLB configure window:
#FUSES ECH
//#FUSES PLL_SW
#FUSES NOIESO
//or
#FUSES ECH
#FUSES PLL
#FUSES NOIESO
Using internal oscillator the below fuses makes PLL Disabled in MPLAB configure window:
#FUSES INTRC_IO
#FUSES PLL
#FUSES NOIESO
#use delay(internal=32M)
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,stream=PORT1,errors)
And in the LST file:
Configuration Fuses:
   Word  1: 0FDC   INTRC_IO WDT PUT MCLR NOPROTECT NOCPD BROWNOUT NOCLKOUT NOIESO NOFCMEN
   Word  2: 1AFF   NOWRT PLL_SW STVREN BORV25 NODEBUG NOLVP
BUT using internal oscillator & fuses as above, including "PLL" the control LED blinks correct,
the serial communication works correct, pwm to an AC motor works correct. To my knowledge, I don't have any place I am enabling PLL in the software.
Best wishes
Joe
PostPosted: Sat Sep 17, 2016 7:53 am     Reply with quote
I don't have that PIC so I can't say for certain....
Without seeing your program I can't tell, but the fuse PLL_SW is enabled...
The compiler may default to 'enable' based on the fuse being enabled ??
Jay
gjs_rsdi
PostPosted: Sat Sep 17, 2016 8:27 am     Reply with quote
Thanks for the answer Jay
The complete fuses:
#include <16F1847.h>
#device ADC=10
#FUSES WDT                      //Watch Dog Timer
#FUSES PUT                      //Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOCPD                    //No EE protection
//#FUSES ECH                  //external clock
#FUSES INTRC_IO            //internal oscillator
//#FUSES HS                  //crystal oscillator
#FUSES PLL
#FUSES NOCLKOUT                 //I/O function on OSC2for internal oscillator & external clock
#FUSES NOIESO                     //Internal External Switch Over mode disabled
#FUSES NOFCMEN                    //Fail-safe clock monitor disabled
#FUSES NOWRT                    //Program memory not write protected
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
//#use delay(clock=32M)         //external clock or crystal oscillator
#use delay(internal=32M)      //internal oscilator
Main:
   setup_wdt(WDT_128MS);//~128 ms reset
    port_b_pullups(0xFF);
   setup_adc_ports(sAN4);
      setup_adc(ADC_CLOCK_DIV_32);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);//65.5 ms overflow
   setup_timer_2(T2_DIV_BY_16,130,2);//262 us overflow, 524 us interrupt, 2000Hz
   setup_ccp1(CCP_PWM);
   set_pwm1_duty(zoomp);
    setup_vref(VREF_ON);
   disable_interrupts(INT_TBE);
   enable_interrupts(INT_RDA);
      restart_wdt();
      ADC();
      FUNCTIONS();
The fuses from LST:
Even in the fuses PLL is enabled, the configuration is PLL_SW.
I am sure the controller works at 32MHz, otherwise the led was not blinking correct, the communication to the PC will not work correct and the pwm will not work correct
That's strange!!!
EDITED:
The only way to enable PLL is to change to external:
//#use delay(internal=32MHz)
#use delay(clock=32MHz)
In the CCS wizard if choosing internal, can't chose different CPU Clock Speed than Clock Speed. With Crystal or Clock can chose Clock speed 8MHz and CPU Clock Speed 32MHz and then it enables PLL
Best wishes
Joe
PostPosted: Sat Sep 17, 2016 10:35 am     Reply with quote
My testing shows this puts the PIC into 32 MHz internal osc PLL mode:
#include <16LF1847.h>
#fuses INTRC_IO, NOWDT
#use delay(internal=32MHZ)
This puts it into 8 MHz internal oscillator mode:
#use delay(internal=8MHZ)
The .LST file for the loop in the test program is shown below. This
produces a negative pulse on Pin B0 which is 125 ns long, and a high
time of 375 ns. This was observed with an oscilloscope.
.................... while(TRUE)
....................    RB0 = 0; // Low for 125 ns
0012:  BCF    LATB.LATB0
....................    RB0 = 1;
0013:  BSF    LATB.LATB0
0014:  GOTO   012
We know that at 32 MHz the instruction clock is 8 MHz, so the instruction
cycle period is 125 ns. The BCF instruction sets RB0 low for one
instruction cycle, and we see a 125 ns negative pulse. Therefore we
are running at 32 MHz. There is no crystal attached to the PIC.
Therefore it's running on the internal oscillator.
Test program. Compiled with vs. 5.062. I couldn't find my 16F1847, so
I used an LF part.
#use fast_io(b)
#byte LATB = getenv("SFR:LATB")
#bit  RB0 = LATB.0
output_drive(PIN_B0);
RB0 = 0;
   RB0 = 1;
gjs_rsdi
PostPosted: Sat Sep 17, 2016 3:55 pm     Reply with quote
Thanks for the answer PCM programmer
I have an oscilloscope that can't test too high frequency and I have ready board so I wrote the test program below.
1. Led blinks every second
2. It outputs serial to a terminal on the PC and I enabled time stamp, get message every 2 seconds on internal oscillator
Also in my test program PLL works with internal oscillator:
#device ADC=10
#fuses INTRC_IO
//#use delay(clock=32MHz,oscillator=8MHz)
#define flashled PIN_A0
int ms50cnt=0;
int ms2000cnt=0;
int scomtxwords=0;
#INT_TIMER1
void  TIMER1_isr(void)
   set_timer1(15536);//65.5 ms overflow
   ms50cnt++;
#INT_TBE
void  TBE_isr(void)
   switch(scomtxwords)
      case 0:
         putc(85);
         scomtxwords++;
      case 1:
         putc(170);
         scomtxwords++;
      case 2:
         putc(255);
         scomtxwords=0;
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);      //65.5 ms overflow
   enable_interrupts(INT_TBE);
      if(ms50cnt>=10)
         output_toggle(flashled);
         ms50cnt=0;
         ms2000cnt++;
         if(ms2000cnt>=4)
            ms2000cnt=0;
But:
1. The configuration bytes shows PLL_SW with #use delay(internal=32MHZ) and PLL with #use delay(clock=32MHz,oscillator=8MHz)
   Word  1: 0FC4   INTRC_IO NOWDT PUT MCLR NOPROTECT NOCPD BROWNOUT NOCLKOUT NOIESO NOFCMEN
   Word  1: 0FC7   ECH NOWDT PUT MCLR NOPROTECT NOCPD BROWNOUT NOCLKOUT NOIESO NOFCMEN
   Word  2: 1BFF   NOWRT PLL STVREN BORV25 NODEBUG NOLVP
2. In MPLAB Configuration bits window 4x PLL Disabled with #use delay(internal=32MHZ)
3. In the CCS wizard can't enable the PLL on internal clock as I mentioned in my previous post
Can it be a compiler bug?
Best wishes
Joe
PostPosted: Sat Sep 17, 2016 4:04 pm     Reply with quote
I don't have the CCS IDE and therefore can't use the Wizard
and I don't have much interest in it. Just being truthful.
gjs_rsdi
PostPosted: Sat Sep 17, 2016 4:55 pm     Reply with quote
Using the CCS IDE just for the wizard, more easy for me with a new controller (so many options and fuses) and to test certain things regarding what can/can't be done.
But as I wrote the Configuration fuses is PLL_SW but enabled (the frequency correct) and in MPLAB Configuration bits window 4x PLL Disabled with #use delay(internal=32MHZ) it is confusing
Best wishes
Joe
gjs_rsdi
PostPosted: Sat Sep 17, 2016 5:23 pm     Reply with quote
Made a test program for PIC18F26K22
With
#use delay(internal=64MHZ)
LED blinks OK, serial com OK
MPLAB Configuration bits written:
Oscillator used directly
But in LST:
   Word  1: 2800   INTRC_IO NOPLLEN PRIMARY NOFCMEN NOIESO
   Word  2: 3C06   PUT BROWNOUT BORV29 NOWDT WDT32768
   Word  3: B500   CCP2C1 NOPBADEN CCP3B5 NOHFOFST TIMER3C0 CCP2B5 MCLR
   Word  4: 0081   STVREN NOLVP NOXINST NODEBUG
   Word  5: C00F   NOPROTECT NOCPB NOCPD
   Word  6: E00F   NOWRT NOWRTC NOWRTB NOWRTD
   Word  7: 400F   NOEBTR NOEBTRB
So also here like the PLL not used, but in the data sheet diagram can see clearly that to get 64MHz (32MHz in the case of 16F1847) the INTOSC go true 4xPLL
Best wishes
Joe
PostPosted: Sat Sep 17, 2016 5:40 pm     Reply with quote
There is more than one way to turn on the PLL. It can be done in
software. Not just the fuses.
Here's your test program:
#include <18F87K22.h>
#use delay(internal=64MHZ))
while(TRUE);
Look in the .LST file. It's setting up the PIC to use the 16 MHz and the
4x PLL, giving 64 MHz as Fosc:
...... void main(void)
00004:  CLRF   TBLPTRU
00006:  BCF    RCON.IPEN
00008:  MOVLW  70   // 111 = HF-INTOSC output freq. is used (16 MHz)
0000A:  MOVWF  OSCCON
0000C:  MOVLW  40       // Set PLLEN bit = TRUE
0000E:  MOVWF  OSCTUNE
00010:  CLRF   OSCCON2
Look at the PIC data sheet to see the details of the OSCCON, OSCTUNE,
etc., registers.
gjs_rsdi
PostPosted: Sat Sep 17, 2016 6:02 pm     Reply with quote
Thanks PCM programmer
Everything clear now Smile
Can see that also in the 16F1847 LST
Still will be nice to see that also in the software and the config bytes, less confusing (for me in any case)
Best wishes
Joe
PostPosted: Mon Sep 19, 2016 6:54 am     Reply with quote
The reason they use the software selection to enable it, is that they have to....
Read the paragraph before in the data sheet. The internal oscillator, after reset, is always set to the 500KHz mode. (5.2.2.5 in the data sheet). This speed doesn't feed to the PLL. So they have to reprogram the oscillator to get the 32Mhz selection.
gjs_rsdi
PostPosted: Mon Sep 19, 2016 10:29 pm     Reply with quote
I understand that Ttelmah, I read the data sheet and PCM programmer teach me where to check to see if PLL enabled or not.
I am just saying again:
Including in MPLAB and maybe some explanation in the CCS help file
Best wishes
Joe
