Data Types in PCWH
bridger
Data Types in PCWH
PostPosted: Tue Dec 16, 2003 1:57 pm     Reply with quote
Greetings,
I'm having a simple but frustrating difficulty with the CCS PCWH compiler on the PIC18F8720. I'm simply trying to have a counter run up to 65535, then roll over and repeat. The code works fine under GNU C. I skimmed the manual and changed the unsigned int to int16, as shown below. But, for whatever reason, CCS treats the variable as an unsigned 8 bit integer, and only compiles if I use %X instead of %u. With %u, the printf generates an error. Code and error follow:
main() {
int16 i ;
printf("Count:") ;
while(1) {
for(i = 0 ; i <= 65535 ; i++)
printf(" %u", i) ;
Error from CCS:
Printf Format Type is invalid
I'm sure there's a glaring and quite obvious solution to all this, but I cannot see it. Can someone please help?
Thanks!
Bridger T. Wray
Mark
PostPosted: Tue Dec 16, 2003 2:45 pm     Reply with quote
Try %lu instead.
Regards,
Mark
miltiades
PostPosted: Tue Dec 16, 2003 2:56 pm     Reply with quote
Mark,
Thanks, %lu works well. I'm still a little frustrated with these compiler quirks and slight differences with ANSI C. I'm sure these will disappear with experience though.
Thanks again for the prompt response,
bridger
PostPosted: Tue Dec 16, 2003 3:59 pm     Reply with quote
miltiades wrote:
Mark,
bridger
It is perhaps worth remembering, that this is C, not ANSI C.
The original Kernighan and Ritchie books for C, specifically say, that an 'int' will be the standard data type for the processor concerned, giving examples of chips with very different default integer sizes.
Now, ANSI C, specifically 'stepped away' from this, to increase code portability, but by doing so, introduces the need to specifically code to the most efficient type, for best speed.
You are much better off using the standard 'K&R' definitions for this C, which are 99% followed.
