about 74ls138 and pic16f877a
huyhust13
PostPosted: Fri Aug 19, 2016 1:52 am     Reply with quote
hi every pro!
can you help me, i dont understand this code when use 74ls138:
void LS138_Out(uint8_t Point)
   LS138_A=((Point&0x01)==0x01);
   LS138_B=((Point&0x02)==0x02);
   LS138_C=((Point&0x04)==0x04);
PostPosted: Fri Aug 19, 2016 2:29 am     Reply with quote
Problem is that you can't fully tell what this is doing without knowing how LS138_A, B & C are defined....
However parts are 'simple':
Point&0x01 Takes the value in 'Point', and bitwise and's it with 0x1.
==0x01 Then tests if this is '1'.
So this can be coded alternatively as:
bit_test(Point,1)
So the result of this test is loaded into LS138_A (whatever this is....).
Now 'guessing', since I know the LS138, that LS138_A, is actually a bit definition of the output latch for the PIC pin connected to the LS138 'A' pin, this then puts the three bottom bits in 'Point', out on the three pins that select which output to turn 'on' (low).
So LS138_Out(0) will pull Y0 low. LS138_Out(1) will pull Y1 low etc..
So in fact the test could be done as:
output_bit(PIN_LSA, bit_test(Point,1));
Where 'PIN_LSA' is a pin define for the pin for the LS138 A connection.
Like most things in C, there are actually dozens of ways of coding the same result...
