Conversion between ASCII and float.
Aayush13
PostPosted: Wed Aug 17, 2016 8:11 am     Reply with quote
Hey guys, I am trying to convert an array of characters to float, do a calculation and then convert that back into chars and then print out the result. I am inputting the resistor value on LabView and printing out the P value over at LabView as well. Here is my code so far:
void main() {
   while(TRUE) {
     int c;
     int count;
     float V, P;
     char arr[50];
     c = getchar();
     count = 0;
     while ((count < 50) && (isdigit(arr[count]))) {
         arr[count] = c;
         ++count;
         c = getchar()
         V = 25.00;
         strcpy(arr, "125");
         P = atof(arr);
         P = (V*V)/(c);
         ftoa(P, arr, 1);
         puts(arr);
      while(arr[i] = '\0') {
         putchar(arr[i]);
         i++;
I put 125 just for testing purposes. Thanks!
PostPosted: Wed Aug 17, 2016 8:32 am     Reply with quote
Er.
strcpy(arr, "125"); //The array 'arr' in memory is now '1' '2' '5' '\0'
P = atof(arr); //P now =125.0
//P = (V*V)/(c); //You now throw away P!.....
P=(V*V)/P; //will give (25*25)/125
Also, on the earlier code 'reading in' the characters, after the last character is loaded, you need to add the '\0' to the string.
In C, a 'string', is an array of characters _terminated with a NULL_. The NULL needs to be there before you use any other 'string function' on the array.
Aayush13
PostPosted: Wed Aug 17, 2016 8:42 am     Reply with quote
Ttelmah wrote:
Er.
Thanks for the reply! I edited my code and compiled and ran it but whatever number I put in LabView for the resistor is the answer I get for P. I'm not sure why it's not carrying out the calculation. Sad
Aayush13
PostPosted: Wed Aug 17, 2016 11:22 am     Reply with quote
PCM programmer wrote:
Post the complete test program, not just the code in main(). Post the
#include line for the PIC, #fuses, #use delay(), #use rs232(), any other
#include lines, and global variables, and then the main().
#include <protoalone.h>
#include <stdio.h>
#include <stdlib.h>
#include <input.c>
#include <conversion.c>
#include <math.h>
#include <ctype.h>
protoalone.h includes:
#include <16f877A.h>
#fuses HS, NOLVP, NOWDT, NOPROTECT
#use delay (clock=20000000)
#define GREEN_LED PIN_A5
#define YELLOW_LED PIN_B4
#define RED_LED PIN_B5
#define PUSH_BUTTON PIN_A4
#use rs232 (baud=9600, xmit=PIN_c6, rcv=PIN_C7)
conversion.c is the C program implementation of ftoa().
PostPosted: Wed Aug 17, 2016 1:56 pm     Reply with quote
The following program compiles and runs in MPLAB vs. 8.92 simulator.
It displays the following output, and it's correct (25 * 25) / 125 = 5
5.000
It doesn't do any keyboard input, but that's easily checked by just
printing the buffer after you get the input. If it looks OK, then your
input code is working.
If that works, then the problem is likely in your ftoa() function.
Test program:
//#include <stdio.h>
#include <stdlib.h>
//#include <input.c>
//#include <conversion.c>
//#include <math.h>
//#include <ctype.h>
int i;
int c;
int count;
float V, P;
char arr[50];
count = 0;
V = 25.00;
strcpy(arr, "125");
P = atof(arr);
P=(V*V)/P; // *** Added by Ttelmah
sprintf(arr, "%7.3f", P);  // *** Substituted for ftoa()
puts(arr);
while(TRUE);
Aayush13
PostPosted: Wed Aug 17, 2016 2:05 pm     Reply with quote
5.000
Test program:
#include <stdlib.h>
//#include <math.h>
int i;
int c;
int count;
float V, P;
char arr[50];
count = 0;
V = 25.00;
strcpy(arr, "125");
P = atof(arr);
puts(arr);
while(TRUE);
Thanks! It works! If I wanted to input numbers from LabView instead of use "125" would I need to do get_float() instead of "125"?
PostPosted: Wed Aug 17, 2016 3:40 pm     Reply with quote
get_float() requires that the incoming ASCII text must end with a
carriage return character (13 in decimal, 0x0D in hex).
If Labview does send a carriage return at the end, then you can replace
these two lines,
strcpy(arr, "125");
P = atof(arr);
with this line:
P = get_float();
Aayush13
PostPosted: Thu Aug 18, 2016 7:29 am     Reply with quote
these two lines,
strcpy(arr, "125");
P = atof(arr);
with this line:
P = get_float();
So I tried this method but whatever I put as the input is what I get for the output. For ex. if I enter 65 for the resistor value on LabView, I get 65 for P as well on LabView. It doesn't seem to be carrying out the calculation?
PostPosted: Thu Aug 18, 2016 8:03 am     Reply with quote
Maybe it's a Labview problem?
try disconnecting the PIC from the PC, see what happens when you enter 65 ..
try a terminal program like RealTerm ,see what happens...
what's the hardware between PIC and PC ?
The PIC code here by PCM P is solid.
Jay
Aayush13
PostPosted: Thu Aug 18, 2016 8:24 am     Reply with quote
Jay
So on LabView I am using the VISA palettes. It writes the value of the resistor and reads the result which is the value of the power.
I tried disconnecting the PIC from the PC and running it but I still get the same answers for the input and output. Unfortunately, I am only limited to using CCS C and LabView for this project.
I am not sure what you mean by hardware between PIC and PC but I'm using ICD-U64 to connect them if that's what you mean? Thanks!
PostPosted: Thu Aug 18, 2016 9:37 am     Reply with quote
hmm..
OK, that shouldn't happen !
The ICD-U64 is an in-circuit debugger chunk of hardware, which I don't use.
Other who do will be able to help but it sounds like the PIC is never really connected to the Labview program, so 5 out = 5 in,125 out = 125 in which is what I think you're seeing.
Jay
PostPosted: Thu Aug 18, 2016 12:03 pm     Reply with quote
The ICD, won't give you a serial connection to Labview. That is not what it does. You need separate serial hardware to link the PIC to the PC.....
