Locate array in BANK0 and BANK1
Max
PostPosted: Wed Dec 10, 2003 11:45 am     Reply with quote
array TXBuffer in BANK1
array RXBuffer in BANK2
is possible following code (IAR) in CCS ??
// Buffers for transmitted and received data
// These are put into different banks so that they can be as large as possible
// The TX buffer is filled up with data to be sent in the next data packet
// The RX buffer is a ring buffer in which received data is stored waiting to be
// sent to the UART
volatile __bank1 char TXBuffer[TX_BUFFER_SIZE];
volatile __bank2 char RXBuffer[RX_BUFFER_SIZE];
Neutone
Re: Locate array in BANK0 and BANK1
PostPosted: Wed Dec 10, 2003 1:18 pm     Reply with quote
// sent to the UART
This places a 64 byte buffer in bank 1
int8  PacketBuffer[64];
#locate PacketBuffer = 0x100
Having the array start at byte 0 within the bank also reduces code required for indirect addressing by 1 instruction per access.
