16F1764 PWM5 not working
johnl
PostPosted: Wed May 04, 2016 9:44 pm     Reply with quote
Pin C3 toggles as it's supposed to, but there's no PWM output on pin C2 (or any other pin.). PCM V. 5.055
#include <16f1764.h>
#include <stdlib.h>
#fuses INTRC_IO,NOWDT, PUT, MCLR, NOPROTECT,NOBROWNOUT, NODEBUG, NOLVP
#fuses NOPPS1WAY
#use delay(INTERNAL = 32000000)
#PIN_SELECT PWM5=PIN_C2 //select the PWM 5 pin
{  set_tris_c(0);
   port_a_pullups(0b1011);
   set_tris_a(0b1011);
   setup_pwm5(PWM_STANDARD | PWM_CLK_FOSC | PWM_CLK_DIV_BY_1);
   set_pwm5_period(0x3FFF);
   set_pwm5_duty(0x1FFF);
      output_toggle(PIN_C3);  //chip is alive. Instruction clock = 8 MHz
      delay_us(125);
johnl
PostPosted: Thu May 05, 2016 3:08 pm     Reply with quote
This is similar problem I had with the 16F1765 except that chip worked sometimes. (see thread:http://www.ccsinfo.com/forum/viewtopic.php?t=54871&postdays=0&postorder=asc&highlight=16f1765&start=0)
The code is basically Ttelmah's from that other thread.
I tried changing the output to C3 but still no PWM output.
Any ideas?
johnl
PostPosted: Thu May 05, 2016 5:22 pm     Reply with quote
Does the C code look like it should work?
If so, and it's not my hardware which only contains a 0.1uF bypass cap and a programming header, could this be compiler bug?
Here's the asm file (minus the includes):
.................... #fuses INTRC_IO,NOWDT, PUT, MCLR, NOPROTECT,NOBROWNOUT, NODEBUG, NOLVP
.................... #fuses NOPPS1WAY
.................... #use delay(INTERNAL = 32000000)
0003:  MOVLW  02
0004:  SUBWF  26,F
0005:  BTFSS  03.0
0006:  GOTO   014
0007:  MOVLW  20
0008:  MOVWF  05
0009:  MOVLW  06
000A:  MOVWF  04
000B:  MOVF   00,W
000C:  BTFSC  03.2
000D:  GOTO   014
000E:  GOTO   012
000F:  GOTO   010
0010:  GOTO   011
0011:  NOP
0012:  DECFSZ 00,F
0013:  GOTO   00F
0014:  MOVLP  00
0015:  GOTO   05B (RETURN)
.................... #PIN_SELECT PWM5=PIN_C2 //select the PWM 5 pin
.................... void main(void)
0016:  MOVLW  55
0017:  MOVLB  1C
0018:  MOVWF  0F
0019:  MOVLW  AA
001A:  MOVWF  0F
001B:  BCF    0F.0
001C:  MOVLW  10
001D:  MOVLB  1D
001E:  MOVWF  22
001F:  MOVLW  55
0020:  MOVLB  1C
0021:  MOVWF  0F
0022:  MOVLW  AA
0023:  MOVWF  0F
0024:  BSF    0F.0
0025:  MOVLW  F0
0026:  MOVLB  01
0027:  MOVWF  19
0028:  MOVLB  03
0029:  CLRF   0C
002A:  CLRF   0E
002B:  MOVLB  02
002C:  CLRF   12
002D:  CLRF   13
002E:  CLRF   11
002F:  MOVLW  04
0030:  MOVWF  10
0031:  MOVLB  00
0032:  CLRF   20
0033:  CLRF   21
.................... {  set_tris_c(0);
0034:  MOVLW  00
0035:  MOVLB  01
0036:  MOVWF  0E
....................    port_a_pullups(0b1011);
0037:  MOVLW  0B
0038:  MOVLB  04
0039:  MOVWF  0C
003A:  MOVLB  01
003B:  BCF    15.7
....................    set_tris_a(0b1011);
003C:  MOVWF  0C
....................    setup_pwm5(PWM_STANDARD | PWM_CLK_FOSC | PWM_CLK_DIV_BY_1);
003D:  MOVLB  1B
003E:  BCF    1B.7
003F:  MOVLB  01
0040:  BCF    0E.2
0041:  MOVLB  1B
0042:  CLRF   20
0043:  CLRF   5F
0044:  CLRF   5C
0045:  CLRF   1E
0046:  MOVLW  80
0047:  MOVWF  1B
....................    set_pwm5_period(0x3FFF);
0048:  MOVLW  3F
0049:  MOVWF  16
004A:  MOVLW  FF
004B:  MOVWF  15
004C:  BSF    1F.7
....................    set_pwm5_duty(0x1FFF);
004D:  MOVLW  1F
004E:  MOVWF  14
004F:  MOVLW  FF
0050:  MOVWF  13
0051:  BSF    1F.7
....................    while(TRUE)
....................       output_toggle(PIN_C3);  //chip is alive. Instruction clock = 8 MHz
0052:  MOVLB  01
0053:  BCF    0E.3
0054:  MOVLW  08
0055:  MOVLB  02
0056:  XORWF  0E,F
....................       delay_us(125);
0057:  MOVLW  7D
0058:  MOVLB  00
0059:  MOVWF  26
005A:  GOTO   003
005B:  MOVLB  1B
005C:  GOTO   052
005D:  SLEEP
Configuration Fuses:
   Word  1: 39C4   INTRC_IO NOWDT PUT MCLR NOPROTECT NOBROWNOUT NOCLKOUT IESO FCMEN
   Word  2: 1EFB   NOWRT NOPPS1WAY ZCDDIS NOPLLEN STVREN BORV19 NOLPBOR NODEBUG NOLVP
PostPosted: Thu May 05, 2016 6:20 pm     Reply with quote
#fuses NOPPS1WAY
You have MCLR enabled. You need an MCLR pull-up resistor.
johnl
PostPosted: Thu May 05, 2016 6:31 pm     Reply with quote
PCM programmer wrote:
#fuses NOPPS1WAY
The data sheet says that when the config bit enables MCLR, then the PU resistor is enabled. Besides the chip is running, so it's not in the reset state.
PostPosted: Thu May 05, 2016 7:19 pm     Reply with quote
You're right. You pointed that out to me in the previous thread.
I notice you're not setting the Phase register. What happens if you set
it to some small value ?
johnl
PostPosted: Thu May 05, 2016 8:01 pm     Reply with quote
Wow...Good call!
I tried it with two chips on two boards and it worked both times.
Thanks! Very Happy
set_pwm5_phase (32);
johnl
PostPosted: Thu May 05, 2016 8:02 pm     Reply with quote
Does this qualify as a compiler bug?
PostPosted: Thu May 05, 2016 9:05 pm     Reply with quote
I don't think so. The PIC data sheet shows that the Phase register must
be set to something in the timing diagram for Standard 16-bit pwm mode.
