Pin RB1 on 16f873 fails to go completely low.
Josh Davis
PostPosted: Sun Dec 07, 2003 11:20 pm     Reply with quote
Hi guys. I have been at this for hours trying to figure out whats going
on with pin rb1's output.
I checked all the normal stuff and my hardware is ok.
AnyWay here is the scoop. When my switch "toggle" is not pushed
both leds light up fine. When I press the switch d3led turns off but
the other led does not turn all the way off. This is the one connected
to pin rb1.
Measuring voltage at the actual pin it goes from 5vdc to 3.9 when the
switch is pushed...
I re wrote the code to test the pins such as turn on both leds delay
for 10 seconds then turn them off. This worked ok.
Im thinking something is getting confused in the while loop but cant
seem to figure it out...
Thanks for any help. Josh.
code
#include <16F873.h>
#byte porta = 0X05
#byte portb = 0X06
#byte portc = 0X07
#bit TOGGLE = PORTB.0
#BIT Led = PORTB.1
#bit D3LED = PORTC.2
#define on 1 // Logic Value = 1
#define off 0 // Logic Value = 0
#define pushed 0 // Logic Value = 0
// #define True 1 Defined in 16f873.h file
// #define False 0 Defined in 16f873.h file
Void main(void){ // The Actual Program.
set_tris_b(0b00000001);
set_tris_c(0b00000000);
while (true) // While Loop Shall Run Forever.
if (toggle==pushed){ // Test to see if toggle goes low
d3led=off; // If Toggle was pushed turn off led
Led=off;
else d3led=on; // OtherWise Keep Led Turned On.
Led=on;
}} // end of while loop. End of Main
CCS PCM C Compiler, Version 3.112, 12906
Filename: D:\PIC_PROCESSOR\IO.C.LST
ROM used: 36 (1%)
Largest free fragment is 2048
RAM used: 6 (3%) at main() level
6 (3%) worst case
Stack: 0 locations
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 004
0003: NOP
.................... #include <16F873.h>
.................... //////// Standard Header file for the PIC16F873 device ////////////////
.................... #device PIC16F873
.................... #list
.................... #byte porta = 0x05
.................... #byte portb = 0x06
.................... #byte portc = 0x07
.................... #define TOGGLE pin_b1 // Switch "Change here" fails to work
.................... #define D3LED pin_c1 // LED
.................... Void main(void){
0004: CLRF 04
0005: MOVLW 1F
0006: ANDWF 03,F
0007: MOVLW 07
0008: BSF 03.5
0009: MOVWF 1F
000A: MOVLW FF
000B: BCF 03.5
000C: MOVWF 25
.................... set_tris_b(0b00000001);
000D: MOVLW 01
000E: BSF 03.5
000F: MOVWF 06
.................... set_tris_c(0b00000000);
0010: MOVLW 00
0011: MOVWF 07
0012: BCF 03.5
0013: MOVWF 25
.................... while (true)
.................... output_low(d3led);
0014: BCF 25.1
0015: MOVF 25,W
0016: BSF 03.5
0017: MOVWF 07
0018: BCF 03.5
0019: BCF 07.1
.................... if (input(toggle==0))
001A: BTFSS 00.0
001B: GOTO 022
.................... OutPut_High(d3led); //LED GOES HIGH:
001C: BCF 25.1
001D: MOVF 25,W
001E: BSF 03.5
001F: MOVWF 07
0020: BCF 03.5
0021: BSF 07.1
0022: GOTO 014
0023: SLEEP
Kenny
Re: Pin RB1 on 16f873 fails to go completely low.
PostPosted: Mon Dec 08, 2003 12:15 am     Reply with quote
Led=off;
Led=on;
The led is being turned on and off at high speed giving the appearance of being half on (or half off :-).
Need to put braces around the two statements
else {
Led=on;
Also, you can use the CCS function output_bit(), saves handling tris and defining ports.
Humberto
PostPosted: Mon Dec 08, 2003 6:31 am     Reply with quote
Hi Josh
In your previous post http://www.ccsinfo.com/forum/viewtopic.php?t=17747
you asked the same stuff that where answered with a full and excelent explanation by Ttelmah.
I seems that you donīt take care of his answer and his time.
Humberto
PostPosted: Mon Dec 08, 2003 6:44 pm     Reply with quote
Hello Kenny, The C syntax is driving me crazyyyyyyyy
Anyway your solution with the braces worked for the else statement.
Thanks for the help on this. I do recall in a earlier version of the compiler
the same code would have worked ok without the braces, not too sure
which one it was but I shall try find out. Im still thinking this is a bug
with the compiler reason here is the led on port c goes out and if I hook
up led's to the other pins on port b they will also go out
While the braces do indeed make the fix, without them a user in a similar
situation would more than likely pull there hair out on this. There was some
errata on the 16f873 part from microchip. Perhaps the compiler is not taking
this into account.
I dont know asm well enough to desipher exactly whats going on so other
than your help im at a loss.
PostPosted: Mon Dec 08, 2003 6:56 pm     Reply with quote
Hi Humberto
I did read Ttelma previous post. If you look at my current code question
you can see that it uses some of the points he outlined for me.
If perhaps the CCS help file was written by a person that did not assume
we all have years of experience with C, my questions might not appear to be so trivial..
For example look at the ccs help for a for loop. Here is what it says
Statement: for (expr1;expr2;expr3) stmt;
Example:
for (i=1;i<=10;++i)
printf("%u\r\n",i);
That in my humble opinion is a very poor example. No mention about the
int i that needs to be used, not even a couple of lines of supporting
code to explain whats going on.
Whithout stuff like Main, device=, int's etc...... That like the other
CCS Examples are about as useless as a sack of rocks.
You have to have a good working idea with C otherwise your dead in
the water. CCS Needs to look closely at ther hlp file as it sucks. Thankfully
they have this fourm, without it their help desk would be over run with calls.
Thanks... Josh.
Mark
PostPosted: Mon Dec 08, 2003 8:39 pm     Reply with quote
this into account.
The braces are not "a fix". That is how you are supposed to code it! Without them
Led=on;
will be executed everytime through the main loop! This is the way your code would be executed:
    if (toggle==pushed)  // Test to see if toggle goes low
      Led=off;
    Led=on;
Notice that Led = on is sitting there all by its lonesome. If you want more than 1 statement to execute in an if/else you need braces around them.
And now the right way:
Led=on;
      Led=off;
      Led=on;
PostPosted: Mon Dec 08, 2003 10:17 pm     Reply with quote
Ok Mark, I got it Thanks for taking the time to point me in the right direction.
In the actual code are the braces treated like a nop or pause, or is it just
a method of isolating the code segment that you want to execute based
on the entry point of the last statement.
The c syntax seems to screw me up alot.. Guess I need to practice more.
Thanks again . Josh.
prof
About RB1 Problem,
PostPosted: Tue Dec 09, 2003 3:56 am     Reply with quote
Please try to use "#fuses NOLVP". See you, Smile
Mark
PostPosted: Tue Dec 09, 2003 7:01 am     Reply with quote
The braces define a group of instructions to be executed if the conditional statement is met. They do not provide and sort of pause.
Mark
Humberto
PostPosted: Tue Dec 09, 2003 9:15 am     Reply with quote
Josh Davis wrote:
Hi Humberto
Hi Josh, my comments was regarding your code:
       if (toggle==pushed)  //  <<<<<<<< !!!! Here
           Led=off;
          Led=on;
that generate this code:
.................... while (true) // While Loop Shall Run Forever.
.................... if (toggle==pushed){ // Test to see if toggle goes low
0014:  MOVLW  00
0015:  BTFSC  PORTB.0
0016:  MOVLW  01
0017:  XORLW  00
0018:  BTFSS  STATUS.2
0019:  GOTO   01D
.................... d3led=off; // If Toggle was pushed turn off led
001A:  BCF    PORTC.2
Using this code:
#use fast_io(A)
#use fast_io(B)
#define TOGGLE  PIN_B0
//#bit TOGGLE = PORTB.0
#BIT Led      = PORTB.1
Void main(void)
     if(input(!TOGGLE))     //  <<<<<<<<<
        d3led = off; // If Toggle was pushed turn off led
        Led = off;
        Led=on;
you get what you want:
....................      if(input(!TOGGLE))
....................        { // Test to see if toggle goes low
0014:  BTFSC  PORTB.0
0015:  GOTO   019
....................         d3led = off; // If Toggle was pushed turn off led
0016:  BCF    PORTC.2
....................         Led = off;
0017:  BCF    PORTB.1
....................      else
0018:  GOTO   01B
....................         d3led=on; // OtherWise Keep Led Turned On.
0019:  BSF    PORTC.2
....................         Led=on;
001A:  BSF    PORTB.1
....................     }  // end of while loop. End of Main
001B:  GOTO   014
Hope you undestand what I mean.
Regards,
Humberto
