Problem with two max7219
rosiley
PostPosted: Mon Apr 25, 2016 6:10 pm     Reply with quote
Good evening everyone.
I have a question here that I can not solve.
I am using two MAX7219, the first triggering 5 7-segment display showing the value of channel 0 and the second MAX7219 showing channel 1 pic. How should I do the scheduling ? Follows the code.
I can not do the second MAX7219 for the value of channel 1.
#include <18F4553.h>          // Includes header file PIC 18F4553
#device ADC = 12              //Sets 12 bits for the result of the AD conversion
#use delay (clock=20000000)   /*Set the frequency of the crystal to calculate
                              ..of delays */
#use spi(do=pin_D0,clk=pin_D2,bits=16,load_active=1,load=pin_D1,idle=1, stream=MAX1)
#use spi(do=pin_C0,clk=pin_C2,bits=16,load_active=1,load=pin_C1,idle=1, stream=MAX2)
//bits control configuration
#fuses HS
#fuses NOWDT
#fuses PUT
#fuses BROWNOUT
#fuses NOLVP
// It shows the value of the AD converter
int32 hc1, hc2;
// It shows the value of Conversion
int32 hc1result;
int32 hc2result;
// The bits to display configuration in the 7-segment display
int address, data, adqnum, digit[5];
int16 packetmax;
// Packet transmission via spi to the max
void maxsend(int8 channel)
{                                //routine for send information to the max
packetmax=make16(address,data);  //make a 16 bit variable direcc byte high, dato byte low
if(channel == 1)
spi_xfer(MAX1, packetmax);       //transfer using spi software
if(channel == 2)
spi_xfer(MAX2, packetmax);
// Configuration properties MAX7219
void maxsetup()
   // Initialize the first MAX7219. The channel parameter = 1.
   address=0x00, data=0x00,  maxsend(1);  // No-Operation
   address=0x09, data=0xff,  maxsend(1);  // Decode-Mode Register Examples (Address (Hex) = 0xX9)
   address=0x0a, data=0x0f,  maxsend(1);  // Intensity Register Format (Address (Hex) = 0xXA)
   address=0x0b, data=0x05,  maxsend(1);  // Scan-Limit Register Format (Address (Hex) = 0xXB)
   address=0x0f, data=0x01,  maxsend(1);  // Display-Test Register Format(Address (Hex) = 0xXF)
   address=0x0c, data=0x01,  maxsend(1);  // Shutdown Register Format (Address (Hex) = 0xXC)
   // Initialize the second MAX7219. The channel parameter = 2.
   address=0x00, data=0x00, maxsend(2);   // No-Operation
   address=0x09, data=0xff, maxsend(2);   // Decode-Mode Register Examples (Address (Hex) = 0xX9)
   address=0x0a, data=0x0f, maxsend(2);   // Intensity Register Format (Address (Hex) = 0xXA)
   address=0x0b, data=0x05, maxsend(2);   // Scan-Limit Register Format (Address (Hex) = 0xXB)
   address=0x0f, data=0x01, maxsend(2);   // Display-Test Register Format(Address (Hex) = 0xXF)
   address=0x0c, data=0x01, maxsend(2);   // Shutdown Register Format (Address (Hex) = 0xXC)
// The following lines are used for the digits
void algebra_digits()
   // Initialize the first line 7 segments display.. The channel parameter = 1.
   digit[0] = hc1result/1000;
   digit[1] = ((hc1result % 1000)*10)/1000;
   digit[2] = ((((hc1result % 1000)*10) % 1000)*10)/1000;
   digit[3] = ((((((hc1result % 1000)* 10) % 1000) * 10) % 1000 )* 10) / 1000;
   digit[4] = ((((((((hc1result % 1000)* 10) % 1000) * 10) % 1000) * 10) % 1000)* 10) / 1000;
   // Initialize the second line 7 segments display. The channel parameter = 2.
   digit[0] = hc2result/1000;
   digit[1] = ((hc2result % 1000)*10)/1000;
   digit[2] = ((((hc2result % 1000)*10) % 1000)*10)/1000;
   digit[3] = ((((((hc2result % 1000)* 10) % 1000) * 10) % 1000 )* 10) / 1000;
   digit[4] = ((((((((hc2result % 1000)* 10) % 1000) * 10) % 1000) * 10) % 1000)* 10) / 1000;
// Set the analog inputs AN0 to AN4
SETUP_ADC_PORTS(AN0_TO_AN4|VSS_VREF);
// Use the internal clock to the time of acquisition
SETUP_ADC(ADC_CLOCK_Internal);
// Enable global interrupt
Enable_Interrupts(GLOBAL);
// Enables interruption by receiving data in serial
Enable_Interrupts(INT_RDA);
// Enables interruption by overflow of Timer 0
ENABLE_INTERRUPTS(INT_TIMER0);
/* Set Timer 0 Prescaler to increase the machine cycle of 1 : 256 and
mode 8 bits */
SETUP_TIMER_0(RTCC_INTERNAL | RTCC_DIV_256 | RTCC_8_BIT);
// Start the Timer 0 with the value 61 - Interruption every 25ms
SET_TIMER0(61);
maxsetup();
delay_ms(3000); // Delays the start of the display
/* Makes cleaning all the rec variable and makes the controleb maga indexes 0 */
for(cont = 0; cont < 5; cont++) rec[cont] = '\0';
cont = 0;
//Main Loop
while(true)
  for(adqnum=1;adqnum<=100;adqnum++)
  {   //collect 100 samples, I usually do this, u can use your favorite method
         hc1=hc1+read_adc();     //for acquisition.
         delay_us(20);
         hc2=hc2+read_adc();     //for acquisition.
         delay_us(20);
      hc1=hc1*10;
      algebra_digits();           //call algebra routine to get each digit
      address=0x01, data=(digit[0] | 0b10000000), maxsend(1);   //use OR for adding decimal point
      address=0x02, data=digit[1], maxsend(1);
      address=0x03, data=digit[2], maxsend(1);
      address=0x04, data=digit[3], maxsend(1);
      address=0x05, data=digit[4], maxsend(1);
      hc1=0;                      //clean hc1
      hc2=hc2*10;
      address=0x01, data=(digit[0] | 0b10000000), maxsend(2);   //use OR for adding decimal point
      address=0x02, data=digit[1], maxsend(2);
      address=0x03, data=digit[2], maxsend(2);
      address=0x04, data=digit[3], maxsend(2);
      address=0x05, data=digit[4], maxsend(2);
      hc2=0;                      //clean hc2
   SET_ADC_CHANNEL(0);     //Sets the read channel 0
   delay_us(100);          //Channel adjustment time (required)
   hc1 = READ_ADC();       //Does the AD conversion and saves it in the variable ad0
   SET_ADC_CHANNEL(1);     //Sets the read channel 1
   hc2 = READ_ADC();       //Does the AD conversion and saves it in the variable ad1
   hc1result = (hc1 * 5000) /4095;
   hc2result = (hc2 * 5000) /4095;
   delay_ms(100);          //Delay 100ms
PostPosted: Mon Apr 25, 2016 6:43 pm     Reply with quote
What do you mean by "pic" ?
Is it your 12F683 ? Or do you mean a graphic image ?
Is your second MAX7219 connected to your 12F683 ? What pins on the PIC ?
Is there only one 12F683, or are there two of them ?
I'm just trying to get some details that you didn't explain.
rosiley
PostPosted: Mon Apr 25, 2016 6:55 pm     Reply with quote
This is my microcontroller.
I used the pic 16f877a
I used two max7219 and one pic
This code is a example, i go used
the pic 16f877
PostPosted: Mon Apr 25, 2016 7:01 pm     Reply with quote
I'm not sure exactly what your problem is.
What is "channel 1" ?
- Is it the 2nd MAX7219 ?
- Is it a different ADC channel on the PIC ?
And please answer my questions from my previous reply.
rosiley
PostPosted: Mon Apr 25, 2016 7:24 pm     Reply with quote
I am using a 16F877A , the value of AN0 channel will be shown in the first max and the value of AN1 channel will be shown in the second max . I already have the value of AN0 channel being shown , only two are in max I need this figure shows only the first max .
How do I put a picture here.
rosiley
PostPosted: Mon Apr 25, 2016 7:43 pm     Reply with quote
See this video.
https://www.youtube.com/watch?v=ikgQyHx_yB0
PostPosted: Mon Apr 25, 2016 11:59 pm     Reply with quote
You are using a 16F877A, so you many i/o pins.
1. Choose 3 unused i/o pins on the 16F877A, and connect the second
MAX7219 to those pins.
2. Make a second #use spi() statement for the second MAX7219.
3. Use streams with the #use spi() statements. The first #use spi()
should have stream=MAX1 added to it. The second #use spi() should
have stream=MAX2 added to it.
Example:
Let's assume the second MAX7219 is placed on PortB. The two #use spi()
statements would be given stream names like this:
#use spi(do=pin_a0,clk=pin_a2,bits=16,load_active=1,load=pin_a1,idle=1, stream=MAX1)
#use spi(do=pin_b0,clk=pin_b2,bits=16,load_active=1,load=pin_b1,idle=1, stream=MAX2)
Then modify the maxsend() function to have a parameter for the channel.
If channel 1 is specified, then send SPI data to the first MAX7219. If
channel 2 is specified, then send it to the second MAX7219:
void maxsend(int8 channel){
   if(channel == 1)
   if(channel == 2)
When you call the maxsend() function, you must specify which MAX7219
chip you want to talk to. This is done with the channel parameter.
Example:
void maxsetup(){
In the rest of your program, you must do the same thing. Put in the
channel parameter in maxsend() to write to the desired MAX7219 chip.
