RS485 interrupt
anemo
RS485 interrupt
PostPosted: Sun Apr 24, 2016 12:37 pm     Reply with quote
Hello!
I'm trying to RS485 communication between two PIC16F887 with a simple code. RS485 is necessary, because i'd like to use at least 10 slaves and long distances.
In first phase, i'm trying the code in virtual (yes... in isis), but something is wrong, because the hardware interrupt works once. The second, third etc. messages don't make rda interrupts in slave, so the incomming_rs485() function runs once in the beginning.
I'm using MAX487 ICs, resistors etc.
What is missing from the code? Thanks for help!
(Sorry for my English)
MASTER:
// MASTER
#include <16f887.h>
#fuses HS,NOMCLR,NOWDT,NOPROTECT,NOLVP,NODEBUG
#use delay(crystal=20000000)
#define RS485_ID 0x00
#define RS485_RX_ENABLE PIN_C2
#define RS485_ENABLE_PIN PIN_C2
#define RS485_USE_EXT_INT FALSE
#include <rs485.c>
int data[5] = {"hello"};
   rs485_init();
   while(true)
      if (rs485_send_message(0x01, 5, data))
            output_toggle(PIN_A0);
SLAVE:
// SLAVE
#include <16f887.h>
#define RS485_ID 0x01
#include <rs485.c>
unsigned int data[16];
   rs485_init();
   while(true)
      if (rs485_get_message(data, false))
PostPosted: Sun Apr 24, 2016 12:44 pm     Reply with quote
please..
Read PIC101 sticky.
We cannot help you with ISIS/proteus 'code' as it is busted, broken, full of faulty DRCs.....
Use real hardware and use the CCS examples (they both work !!).
Jay
PostPosted: Sun Apr 24, 2016 2:09 pm     Reply with quote
Read this previous thread on how to make rs-485 work with CCS.
This is a 3-page thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=52757
PostPosted: Mon Apr 25, 2016 2:05 am     Reply with quote
There is also the glaring problem with this declaration:
The array is too small to hold what is being put into it.
A five character string _requires_ six characters of storage....
anemo
RS485 interrupt
PostPosted: Mon Apr 25, 2016 7:32 am     Reply with quote
Hello!
As I said, in the first phase, i'd like to try it in virtual, but i'll build this circuit for you, after i bought devices (soon).
I have already read it (before i posted) and my "circuit" is similar to that.
Thanks, i fixed it, but the code is still not working. The slave's led doesn't blink.
PostPosted: Mon Apr 25, 2016 3:47 pm     Reply with quote
You're basing 'it doesn't work' on a faulty 'simulation' program aka ISIS aka Proteus !
drolleman
PostPosted: Mon Apr 25, 2016 6:57 pm     Reply with quote
Even for a first phase, simulators are not worth the time. You can chase bugs that real hardware will work with, and others that real hardware won't work with. Bottom line, experienced developers don't use simulators, it doesn't save time.
anemo
reply
PostPosted: Sun May 01, 2016 7:00 pm     Reply with quote
Hello!
So, Today I built the real hardware:
https://drive.google.com/file/d/0B5gu1D-K_ShcTEpxTVByRWhlSDA/view?usp=sharing
And I have to apologize to you, because it works... I've already built some circuits with proteus, and they worked in real, unfortunately the simulator is wrong in this situation and I made a mistake because of it..
So.. sorry and thank you for showing the right way.
PostPosted: Mon May 02, 2016 12:15 am     Reply with quote
Very Happy
You now know why there are so many posters here saying 'ignore what Proteus/Isis say'....
Generally, small very simple projects will work in Isis. However as things get more complex, the probabilities of it giving the right answer, 'shoot down'.
There are little errors in almost every Isis component in the PIC's.
I've got two demo projects, one shows a project that works perfectly in Isis, but can never work in the real world. The second shows a project that will not function in Isis, but works for real (you now have your own example of this....).
A few years ago (Okay, Isis was younger then), a company I worked for did a 'viability study', evaluating whether certain tools were worth paying the charges to keep up to date or not. The product that came _lowest_ on the list at the end of the study, was Isis. Basically they found that every microprocessor project where Isis was used, took longer to complete, than similar projects done without this tool....
Duh!.
We use Proteus as a PCB design tool, and still will use Isis for a few specific analog simulations, as being quicker than Spice to set up (it works well for these simulations), but when it comes to microprocessor sections, Isis is not used at all.
