error after compiler update
garryw
PostPosted: Fri Apr 15, 2016 2:11 pm     Reply with quote
I was using ver 4.141 and could compile without errors.
I updated to ver 5.057 and now get the following:
*** Error 99 "main.c" Line 45(5,68): Option invalid Software PWM frequency is not achievable with Timer 2
*** Error 99 "main.c" Line 46(5,68): Option invalid Timer2 already being used for another PWM
I can deal with the first error by changing the frequency, it's the second one I'm not sure how to deal with.
#if defined(__PCH__)
#include "18F67J93.h"
#ignore_warnings 202,240
#DEVICE ADC=10
#device *=16
#fuses WDT,NOPROTECT,INTRCPLL_IO,NODEBUG,CCP2C1
#use fast_io(all)
#use delay(clock=8000000)
#use rs232(uart1, baud=9600, RESTART_WDT, PARITY=N, BITS =8, STOP=1,stream=PC)
#use spi(FORCE_HW, BITS=8, baud=9600, MODE=0)
#USE PWM(PWM2,OUTPUT=PIN_C1,FREQUENCY=10kHz,DUTY=0)//unlatch C1 P2A
#USE PWM(PWM1,OUTPUT=PIN_C2,FREQUENCY=10kHz,DUTY=0)//unlatch C2 P1A
#use fast_io(ALL)
#include <stdio.h>
#include <stdlib.h>
PostPosted: Fri Apr 15, 2016 3:11 pm     Reply with quote
It compiles if I add FORCE_HW to each #use pwm() statement, as shown below in bold:
#DEVICE ADC=10
#device *=16
#use fast_io(all)
#USE PWM(PWM2, OUTPUT=PIN_C1, FREQUENCY=10kHz, DUTY=0, FORCE_HW)//unlatch C1 P2A
#USE PWM(PWM1,OUTPUT=PIN_C2,FREQUENCY=10kHz,DUTY=0, FORCE_HW)//unlatch C2 P1A
#use fast_io(ALL)
#include <stdio.h>
#include <stdlib.h>
Compiler output (with vs. 5.057):
Executing: "C:\Program files\Picc\CCSC.exe" +FH "PCH_Test.c" +DF +LY -T -A +M -Z +Y=9 +EA #__18F87J93=TRUE
--- Info 300 "PCH_Test.c" Line 10(1,1): More info: PWM Resolution: 9.64 bits
Memory usage: ROM=0% RAM=0% - 0%
0 Errors, 0 Warnings.
Build Successful.
Loaded C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.cof.
BUILD SUCCEEDED: Fri Apr 15 14:12:11 2016
garryw
PostPosted: Mon Apr 18, 2016 6:22 am     Reply with quote
Thank you so much for the FORCE_HW. That did the trick.
