Posted: Mon Dec 08, 2003 10:16 am |
Mark wrote: | I only suggested the test for zero/ nonzero changed. I never said a damn thing about CCS enabling/disabling interrupts! All the code I posted was from the C18 compiler not CCS.
Quote: |
Only if you are counting in ones. The problem _still remains_ if the 6F byte can change between the two lines.
I don't care what units I am counting in. If I check the high byte first and it is a non zero value, then it doesn't matter what the low value is!
Bad way:
MOVLB 0x0 while (Note);
MOVF 0x6f,0x0,0x1
IORWF 0x70,0x0,0x1
BZ 0xba6
BRA 0xb9c
Better way
MOVF 0x70,0x0,0x1
IORWF 0x6f,0x0,0x1
BZ 0xba6
BRA 0xb9c
Quote: |
Basically, you are asking CCS to modify the compiler to suit a particular useage you have, which may well cause problems in other situations (I would not want interrupts disabled for each test involving a number accessed both inside and outside an ISR), when this can already be done by coding carefully yourself.
Again, I don't care what they do. I just said it would be better! If I wanted them to change it, I would have emailed them! And again, if they wanted to change it, they could have their normal case and then a special case when the variable is volatile. |
You are missing the point.
Your 'better' way, is only better if you are counting downwards. If the count is up, it is better to use the CCS approach. If the count is at FFFF, and wraps to zero between the tests, exactly the same problem exists when you test the high byte first, as when you test the low byte first and the count is down with the standard code.
Given that the default CCS hardware counts upwards, it makes sense for the compiler to make this the default...
DragonPIC
I like flags. |
Posted: Mon Dec 08, 2003 2:22 pm |
I have had problems like this in the past, or have just worried about it. It's just like an interrupt being called before you have a chance to compare an "if equal to" statement. The variable gets incremented or decremented before you had a chance to comare the #'s and you miss your #. You then have to wait for the variable to go around the ben again (0x00 to 0xFF and down again). If your interrupt is that close where it cannot make the complete compare before the variable changes again, you are getting yourself into more trouble than just comparing MSB or LSB first. As your projects grows, it may just come back to kick you in the a**. By that time, the conflict in your program may be even harder to debug.
I guess it has become more of a habit for me now to just set flags in the interrupt, or making the compare and all needed actions inside the interrupt. |
Re: I like flags. |
Posted: Mon Dec 08, 2003 3:11 pm |
DragonPIC wrote: | I have had problems like this in the past, or have just worried about it. It's just like an interrupt being called before you have a chance to compare an "if equal to" statement. The variable gets incremented or decremented before you had a chance to comare the #'s and you miss your #. You then have to wait for the variable to go around the ben again (0x00 to 0xFF and down again). If your interrupt is that close where it cannot make the complete compare before the variable changes again, you are getting yourself into more trouble than just comparing MSB or LSB first. As your projects grows, it may just come back to kick you in the a**. By that time, the conflict in your program may be even harder to debug.
Exactly.
You accept that whichever way the compiler did it, there would be a potential problem, and handle it.
