Fastest way to set outputs to 0 on power up
dazlogan
PostPosted: Mon Dec 08, 2003 1:08 pm     Reply with quote
Hi everyone,
I need to set several outputs to 0 (low) on power up as an absolute priority. I am wondering - what is the fastest way of doing this in code please anyone?
Regards,
Darren
Mark
PostPosted: Mon Dec 08, 2003 1:14 pm     Reply with quote
Well, that depends. If it is an entire port, then just setting that port to 0 is fast. If setting only 1 output then setting that output to 0 is probably the fastest. If setting more than 1 output but less than 8, setting the port to a known state is fast or you can even 'AND' the port with a mask of 1's and 0's.
dazlogan
PostPosted: Mon Dec 08, 2003 1:22 pm     Reply with quote
Hi Mark,
Thanks.
Let's say port_a, port_b and port_c all need to go low.
Being more specific - is it best to put something like:
main () {
output_a(0x00);
output_b(0x00);
output_c(0x00);
or is there a quicker way of doing it?
Mark
PostPosted: Mon Dec 08, 2003 1:26 pm     Reply with quote
That's about the fastest way that I know. You can probably save a couple of instructions by using "fast_io" and setting the TRIS registers all at one time.
Neutone
PostPosted: Mon Dec 08, 2003 2:12 pm     Reply with quote
Have a look at the datasheet and see what the powerup timer does. During powerup all port pins are inputs and a pull down resistor will keep you safe but thats a hardware fix.
SherpaDoug
PostPosted: Mon Dec 08, 2003 3:59 pm     Reply with quote
By default the ports power up in tri-state. So if you put a pull down resistor on them they will power up in a low state before the processor even comes out of reset. They will stay low untill your code makes them otherwise.
Haplo
PostPosted: Mon Dec 08, 2003 4:00 pm     Reply with quote
And as Neutone said all the ports are set to input on power-up, so before setting them to zero you have to configure them as outputs (if you are using #use fast_IO).
Using code
PostPosted: Mon Dec 08, 2003 5:05 pm     Reply with quote
Hardware is the best choice, however to make sure each port is LOW (or high as you please) Set the ouput before setting the TRIS .
This is about the fastest way I know, if Port A if more cirtical than Port C then output that first.
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
#byte portA = 0XF80 // for PIC18 series
#byte portB = 0XF81
#byte portC = 0XF82
#byte TRIS_A = 0XF92 // for PIC18 series
#byte TRIS_B = 0XF93
#byte TRIS_C = 0XF94
portA = portB = portC = 0; // set low before changing TRIS
TRIS_A = TRIS_B = TRIS_C = 0; // all outputs are low NO glitches
other code..
That's abut 600nS at 40MHz...
Here's the LST file for it.
.................... portA = 0;
0012: CLRF F80
.................... portB = 0;
0014: CLRF F81
.................... portC = 0; // set low before changing TRIS
0016: CLRF F82
.................... TRIS_A = 0;
0018: CLRF F92
.................... TRIS_B = 0;
001A: CLRF F93
.................... TRIS_C = 0; // all outputs are low NO glitches
001C: CLRF F94
hansw
dazlogan
thanks!
PostPosted: Tue Dec 09, 2003 4:06 pm     Reply with quote
Thanks Hans and everyone else.
My problem is cured !. Most appreciated.
Regards,
Darren
