cyrildavids
Posted: Sat May 09, 2009 2:30 am |
| How do one configure this for a 4x 20 lcd screen with the same driver? |
mutthunaveen
Joined: 08 Apr 2009 Posts: 100 Location: Chennai, India
| wow it is a good BAR graph |
Posted: Sun Sep 13, 2009 10:12 am |
I am very much thankful to you
And I have a small problem with the display flickering is on the screen. It is something like scrolling effect... same as CRT interlacing.
What I have to modify to the code to get a clear display? |
Jeff7
Posted: Sun Oct 04, 2009 10:16 pm |
I think that a flickering effect like that can result from very rapid updates to the display. Either add in some kind of a delay, or else have a timer-triggered flag to enable an update, perhaps every 100-200mS.
Nifty bar graph...I didn't even see this thread.
I wound up digging up something on an old blog post, and made my own addition to LCD.c. I also tied the graph levels right to ASCII codes 0-7, so printf(lcd_putc,"%c",5); would result in printing a block with 6 rows filled in.
And of course you can program in something to check for a value greater than 7, decrement the value by 8, move to row 1, and print the new value. Badda-bing, you've got a 16-row bar, albeit with a small gap above the first 8 rows. |
mutthunaveen
| yea |
Posted: Mon Oct 05, 2009 6:05 am |
I thought the same. I mean increasing the delay (LCD refresh rate).
Thanks for your reply.
When I decrease the refresh rate then the interactive bar graph is struggling to display the sudden changes happening.
Anyway thanks  |
mbradley
Joined: 11 Jul 2009 Posts: 118 Location: California, USA
Posted: Mon Dec 14, 2009 2:00 am |
Here is one from my site, works with the eadog driver, but you can tweek it to work with most any lcd that has custom chr's.
First call: gBarGraphIni(); to program the custom chr's.
Then call the graph function with a pos, max. This is what POS in MAX
so 50,100 would be half way, same as 256, 512.
gBarGraph(row,pos,max);
If you need a graph that does not span the entire row, then use the advanced one. WIDTH is the chr's positions wide.
gAdvBarGraph(row,col,width,pos,max)
// note: this calls the functions in the EA-DOGM driver
// sets up the programmable chr's for use as a bar graph
//uses custom chrs 1 to 5
void gBarGraphIni(void)
int i;
for (i=0; i<8; i++) { eaDogM_WriteByteToCGRAM(0b00001000 + i,0b0010000); }
for (i=0; i<8; i++) { eaDogM_WriteByteToCGRAM(0b00010000 + i,0b0011000); }
for (i=0; i<8; i++) { eaDogM_WriteByteToCGRAM(0b00011000 + i,0b0011100); }
for (i=0; i<8; i++) { eaDogM_WriteByteToCGRAM(0b00100000 + i,0b0011110); }
for (i=0; i<8; i++) { eaDogM_WriteByteToCGRAM(0b00101000 + i,0b0011111); }
void gBarGraph(char row, unsigned int16 pos, unsigned int16 max)
int8 i,m,r;
int32 n;
eaDogM_SetPos(row,0);
n = ( (pos * 80) / max );
m = n / 5; // i love integer math, 6/5 = 1 not 1.2 :)
r = n - (m * 5); // get the remainder
for (i=0; i<m; i++) { eaDogM_WriteChr(5); } // block chr
eaDogM_WriteChr(r);
for (i=(m+1); i<16; i++) { eaDogM_WriteChr(0x20); } // end spaces
void gAdvBarGraph(char row, char col, char width, unsigned int16 pos, unsigned int16 max)
int8 i,m,r;
int32 n;
eaDogM_SetPos(row,col);
n = ( (pos * (width*5)) / max );
eaDogM_WriteChr(r);
for (i=(m+1); i<width; i++) { eaDogM_WriteChr(0x20); } // end spaces
_________________ Michael Bradley
www.mculabs.com
Open Drivers and Projects |
sandrosachser
Posted: Thu Mar 24, 2016 11:14 am |
| Hello. At first, thank you so much by informations. Is it possible use this bargraph code with LCD 20x4 ? (Note: I use FLEXLCD library) Thank you again. |
