Jerry I
Joined: 14 Sep 2003 Posts: 102 Location: Toronto, Ontario, Canada
| printf problem (Solved) |
Posted: Tue Mar 01, 2016 9:03 pm |
Thank you in advance for any help.
I got a new PIC16F1619 to use CLC Functions
I have used the PIC16F1509 with no problems. The code I ported is from the PIC16F1509 which
worked with no problems.
Compiler version PCM 5.052
The problem is the interupt #int_timer2 routine.
If I uncomment any code in the #int_timer2 routine the printf("Hello World\r\n")
in the main() loop code will get corrupted (chopped up).
I will post part of my program which will compile.
#device PIC16F1619
#include <16F1619.h>
#fuses intrc_io, nowdt, noprotect, nolvp, put
#fuses nomclr, nodebug
#device *=16
#device adc=8
#byte TRISA = getenv("SFR:TRISA")
#byte TRISB = getenv("SFR:TRISB")
#byte TRISC = getenv("SFR:TRISC")
// #define CLOCK98MHZ
// #define CLOCK8MHZ
#define CLOCK16MHZ
#define TEST_BIT rc1
#define TEST_BIT2 rc2
#define PHASE_B ra3
#define PHASE_A rc7
// #define EL_PHASE_A rd2
// #define EL_PHASE_B rd3
#case
#ifdef CLOCK8MHZ
#use delay(clock=8000000, internal) //one instruction=0.2us
#ifdef CLOCK16MHZ
#use delay(clock=16000000, internal) //one instruction=0.2us
#ifdef CLOCK98MHZ
#use delay(clock=9830400) /////////// Check Crystal Value ////////////
#define BAUD1_SPEED 9600
#define BAUD2_SPEED 19200
#define BAUD3_SPEED 38400
#use rs232(baud=BAUD1_SPEED,xmit=PIN_B7,rcv=PIN_B5, ERRORS)
int32 tmr0cnt, tmr1cnt;
signed int16 encDelta;
signed int16 last;
signed int32 enc_cnt;
int1 last_A, last_B, new_A, new_B, A_error, B_error;
int16 error_A_cnt, error_B_cnt;
signed int16
DnCount, // Holds accumulated 'up' pulses
UpCount, // Holds accumulated 'down' pulses
prevDnCount, // Previous Holds accumulated 'up' pulses
prevUpCount, // Previous Holds accumulated 'down' pulses
mvelocity, // Measured motor velocity
prev_mvelocity // Holds prev UP/DOWN Counts
signed int32
travel_to,
position, // Commanded position.
mposition; // Actual measured position.
#int_timer2 // Quadrature Encoder read counters
void timer2_isr(void)
signed int16 new, diff;
mvelocity = DnCount; // UNCOMMENTING ANY OF THESE LINES printf gets corrupt
mvelocity -= UpCount; // UNCOMMENTING ANY OF THESE LINES printf gets corrupt
//! prev_mvelocity = mvelocity; // UNCOMMENTING ANY OF THESE LINES printf gets corrupt
//! UpCount = tmr0cnt + get_timer0(); // UNCOMMENTING ANY OF THESE LINES printf gets corrupt
//! DnCount = get_timer1(); // UNCOMMENTING ANY OF THESE LINES printf gets corrupt
#int_timer0 // Quadrature Encoder read counters
void timer0_isr(void)
tmr0cnt = tmr0cnt + 0x0100;
signed int16 cnt = 0;
setup_adc(ADC_OFF);
TRISA = 0b00101011;
port_a_pullups(0x04);
TRISB = 0b11110111; // All Inputs Lower nibble Interrupt on change
TRISC = 0b11010000;
setup_timer_0(RTCC_EXT_L_TO_H|RTCC_DIV_1);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_EXTERNAL_SYNC);
tmr0cnt = 0L;
tmr1cnt = 0L;
set_timer0(0);
set_timer1(0L);
setup_timer_2(T2_DIV_BY_4, 64, 10);
mvelocity = 0;
prev_mvelocity = 0;
DnCount = 0;
UpCount = 0;
prevUpCount = 0;
prevDnCount = 0;
mposition = 0;
clear_interrupt(INT_TIMER0); // Timer
clear_interrupt(INT_TIMER2); // Timer
enable_interrupts(INT_TIMER0); // TIMER2 Int
enable_interrupts(INT_TIMER2); // TIMER2 Int
printf("Hello World Test \r\n\r\n");
printf("Hello World\r\n");
delay_ms(2000);
[img]http://postimg.org/image/5ewb01cid/[/img]
Any Ideas??
Jerry
Posted: Tue Mar 01, 2016 9:30 pm |
| Quote: | If I uncomment any code in the #int_timer2 routine the printf("Hello
World\r\n") in the main() loop code will get corrupted (chopped up). |
That's the symptom of a software UART with its bit timing disrupted by
interrupts. You can see it's a software UART by looking at the .LST file.
To fix it you need to use a hardware UART. Just by playing around with it,
I was able to get the setup code that gives a hardware UART:
#pin_select U1TX = PIN_B7
#pin_select U1RX = PIN_B5
#use rs232(baud=BAUD1_SPEED, ERRORS, UART1) |
This can be confirmed by looking at the .LST file. You will see it's using
the hardware UART registers. |
Jerry I
Posted: Wed Mar 02, 2016 8:04 pm |
Thanks again PCM Programmer.
This is the first time I used a Pic where the use of pin_select for a peripheral.
Now I wondering if the timers that I am using also require to define external input pins as T0CKI and T1CKI with pin_select??.
Thanks again.
Jerry |
Posted: Thu Mar 03, 2016 1:48 am |
| Quote: |
external input pins as T0CKI and T1CKI with pin_select ? |
No, you don't have to. They have default pins. See this table in the
16F1619 data sheet: Table 13-1: PPS Input Register Reset Values
The default pin for Timer0 external clock is RA2.
The default pin for Timer1 external clock is RA5. |
Jerry I
Posted: Thu Mar 03, 2016 2:06 pm |
Thanks for info,
What about the CLC outputs, I will have 2 each feeding the 2 external clock inputs. Do I have to set pin_select pins?.
Thanks again,
Jerry |
Joined: 01 Jul 2010 Posts: 9608 Location: Greensville,Ontario
Posted: Thu Mar 03, 2016 2:49 pm |
This again is easy stuff... just read the datasheet....page 6, table 1 shows the available inputs/outputs including the CLC peripheral.
While I don't have or use this PIC it does seem fairly easy to use....
CCS may have an example of using the CLC, I haven't checked and my version of PCM is rather old, bound to be some 'how to use' stuff in the manual. Interesting PIC though I like the idea of the NCO.......
too many PICs... too little time
Jay |
