Is it possible to measure pulse width and period by one CCP?
40inD
PostPosted: Wed Mar 02, 2016 4:12 am     Reply with quote
Is it possible to measure pulse width AND period by only one CCP? Maybe with using timers?
PostPosted: Wed Mar 02, 2016 6:06 am     Reply with quote
Yes, you should read the Microchip application notes about how to do it as well Search for the apnote about 'measuring pulse width'. CCS may have an example in their extensive folder of example.
What method you choose will be based upon the peripherals available in your PIC.
Jay
PostPosted: Wed Mar 02, 2016 9:08 am     Reply with quote
A CCP, always uses a timer, when measuring pulse widths....
Big critical question is 'how fast'.
Yes it is possible, the problem is that there has to be some 'user intervention', such as changing the edge to be sensed in the interrupt. This takes time, so you can't do this for a really short pulse, or fast repetition rate.
It's basically simple, on the first capture, you toggle the edge to be sensed, and record the first value. On the second you toggle the edge again, and record the second value.
The example posted by Pcm_programmer at the end of this thread:
<http://www.ccsinfo.com/forum/viewtopic.php?t=45616&highlight=pulse+width+one+ccp>
Shows this being done.
40inD
PostPosted: Thu Mar 03, 2016 12:36 am     Reply with quote
It's understood, I have read that post, and measuring pulse width is no problem. But i don't understand, how to calculate period (or frequency) if it can change?
Need to measure 5-10 ms pulse @ 5-50 Hz.
I use 18f25k22 @ 20MHz , only CCP2 free. T1 used, ССP1 used as PWM. But I also have EXT_INT1 and EXT_INT 2 free.
If I feed signal simultaneously into CCP and ext_int, and ext_int will count period with help of some free timer?
Mike Walne
PostPosted: Thu Mar 03, 2016 3:39 am     Reply with quote
What accuracy/resolution are you wanting?
Mike
40inD
PostPosted: Thu Mar 03, 2016 3:51 am     Reply with quote
Let's say 0.1 - 0.2 ms
I think it must look something like this:
#INT_EXT1
void  EXT1_isr(void)
period=get_timer0();
set_timer0(0);
#INT_CCP2  // from PCM programmer code
void  CCP2_isr(void)
static int16 rising_edge;
// If current interrupt is for rising edge.
if(capture_rising_edge)
   setup_ccp1(CCP_CAPTURE_FE);
   capture_rising_edge = FALSE;
   rising_edge = CCP_2;
   setup_ccp1(CCP_CAPTURE_RE);
   capture_rising_edge = TRUE;
   ccp_delta = CCP_2 - rising_edge;
   got_pulse_width = TRUE;
  if(got_pulse_width)
      pulse_width_ms = ccp_delta / (125); // adjust divider
      got_pulse_width = FALSE;
PostPosted: Thu Mar 03, 2016 9:31 am     Reply with quote
Don't do the maths in the interrupt. Look at PCM_programmer's code. He just takes the readings in the interrupts, and this is what you should do.
When it flags 'got_pulse_width', record one of the two readings into a 'temporary' variable. The _next_ time a pulse width is signalled, the time between the reading this time, and the one stored, is the period of the signal.
40inD
PostPosted: Fri Mar 04, 2016 12:14 am     Reply with quote
Ok, thanks.
What do you think about
#INT_EXT1
void  EXT1_isr(void)
set_timer0(0);
PostPosted: Fri Mar 04, 2016 2:22 am     Reply with quote
Look at PCM_programmer's code.....
You are no longer measuring the pulse width.
Just amend it as:
int1 capture_rising_edge;
int1 got_pulse_width;
int16  ccp_delta;
int16 period_delta;
#int_ccp1
void ccp1_isr(void)
   static int16 t1_rising_edge;
   static int16 old_t1;
   static int1 first=TRUE;
      t1_rising_edge = CCP_1;
      period_delta=old_t1-t1_rising_edge;
      old_t1=t1_rising_edge;
      ccp_delta = CCP_1 - t1_rising_edge;
      if (first)
         first=FALSE;
Then when 'got_pulse_width' goes true, there are now _two_ values
recorded. ccp_delta for the pulse width, and period_delta for the
period.
Use exactly the same code as he shows (modified to suit your clock
rate - the '125' needs to change, and if you want pulse times more accurately than 'mSec', you probably don't actually want this), but save a
local copy of period_delta as well as ccp_delta. Then do the
same maths on this to get the pulse period.
