18F1320 not wakeup by int_rb
tssir
PostPosted: Sun Feb 14, 2016 5:59 am     Reply with quote
Pic did not wakeup after hardware change on port b.
Here a simple program:
#include <18F1320.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP
#use delay(clock=1000000)
#USE fast_io(A)
#USE fast_io(B)
#define IO_ONEWIRE_MOSFET PIN_A2
#define IO_3WIREBUS PIN_B0
#INT_RB
void rbHandler(void)
clear_interrupt(INT_RB);
set_tris_a(0b10010010);
set_tris_b(0b00111110);
port_b_pullups(true);
output_bit(IO_ONEWIRE_MOSFET,false);
output_bit(IO_3WIREBUS,false);
disable_interrupts(GLOBAL);
enable_interrupts(INT_RB);
delay_us(200);
   sleep(SLEEP_IDLE);
   // Just to show a result, when wakeup
      output_toggle(IO_3WIREBUS);
      delay_ms(1);
INT_RB is called both time before sleep, without any changes on port b. Program stop at sleep command, with no wakeup by int_rb (but it works with int_timer0).
Compiler version is PCH 5.043.
I should miss something. Thank you for your help.
PostPosted: Sun Feb 14, 2016 6:09 am     Reply with quote
comments..
1) The ISR will automatically clear interrupts, so YOU don't have to.
2) While I don't use that PIC, every other one requires you to read the portB in order to 'clear ' the port. You should find th details in the datasheet, in the I/O ports section, subsection portB.
Jay
tssir
PostPosted: Sun Feb 14, 2016 9:37 am     Reply with quote
1) You are true. Compiler replace clear_interrupt by nothing.
2) I tried to read portB. Nothing changes. But your answer is a very good clue. I am trying to monitor RB1.
Datasheet claims: "The input pins (of RB7:RB4) are compared with the old value latched on the last read of PORTB.".
Then, INT_RB can only monitor RB7 to RB4. Not the whole portB.
I need to change my design.
PostPosted: Sun Feb 14, 2016 9:50 am     Reply with quote
The point about reading the input, is you need to read it inside the ISR.
Otherwise if the interrupt triggers, the code can never leave the ISR, so will seem to never wake:
//chip header etc. omitted to save space
#INT_RB
    int8 dummy;
    dummy=input_state(PIN_B4); //read just one pin - this is all
    //that is needed. This avoids changing your TRIS.
   int8 dummy;
   delay_cycles(10); //allow time for the pins to be pulled high
   dummy=input_b(); //read whole port
   set_tris_b(0b00111110); //now set the TRIS
   clear_interrupt(INT_RB); //in case this was triggered by the pins
   //being pulled high
      sleep(SLEEP_IDLE);
      delay_cycles(1); //The instruction after sleep should be a NOP
      //now your display code etc..
PostPosted: Sun Feb 14, 2016 10:30 am     Reply with quote
I _think_ he wants to see an interrupt on RB0. If so, according to the datasheet, it has it's own interrupt, 'external interrupt 0'.
I use this...
as my clue.
Jay
PostPosted: Sun Feb 14, 2016 2:06 pm     Reply with quote
Except he has B0 defined as an output.....
PostPosted: Sun Feb 14, 2016 2:42 pm     Reply with quote
well I'm confused...don't take much these dayze....
I figured something labelled IO.... was both Input and Output....
Perhaps we'll get a more descriptive program later. I understand English is hard even for a crazy Canuck like myself !
Jay
PostPosted: Sun Feb 14, 2016 2:57 pm     Reply with quote
I think he intends to wake the chip with a trigger on either RB3 or RB4, then use RB0 for the one wire operation. If you look he is currently sending his 'test' signal out on this line, to determine if the chip has woken up, which makes sense in this case.
PostPosted: Mon Feb 15, 2016 12:49 am     Reply with quote
As a general comment, the one thing missing from what I have posted, is the possibility of needing to ensure that other peripherals aren't using the pins involved. Disabling the analog port, and the ECCP. Generally for 90% of chips CCS will ensure that peripherals are disabled at boot, but there is a faint possibility that these are not (possibly depending on compiler version), so it might be worth adding the lines to disable these.
