Low PWM without stress timer
Post new topic   Reply to topic    CCS Forum Index -> Code Library
wangine
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Tue Nov 17, 2015 12:51 pm     Reply with quote
I see here and on internet also many issues trying to get low frequency PWM, of course without stress timer. The function was made trying to get 1Hz PWM with normal duty 0-100.
//   ~~~~~~~~~~~~~~~~~~~~~once at n ms~~~~~~~~~~~~~~~~~~~~~~
#define pwm_pin PIN_x // output PWM pin
#define duty_min  1
#define duty_max 100
void timer_pwm(unsigned int8 duty)
      if(pwm_period <= duty_min)
         output_high(pwm_pin);
      if(pwm_period == duty)
         output_low(pwm_pin);
      if(pwm_period >=duty_max)
      pwm_period = 0;
duty is actual state of PWM between 1-100%
int8 pwm_period = 0;
#INT_TIMER1
void TIMER1_isr(void)
   timer_pwm(open_duty);
   pwm_period++;
Each one can set a timer on any low frequency need. Example, at 10ms timer set, 10*pwm_period=1000 => 1Hz frequency PWM with variable duty. The function can update in any other functions. Also can be easy set any duty limits.
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
