This works really well for a signal that is being measured on a regular basis. This results in a signal thats filtered much like an RC circuit. In an RC circuit one time constant gets you to reach ~66% of the full scale value and ~5 time constants gives you the final value. Using this formula each sample is like a time constant that gives you 1/x of the stable value where x is the number of shifts in the subtraction operation. The number of samaples required to reach a stable value is dependant on the number of shifts.
{ Analog_Input_1_RAW-=(Analog_Input_1_RAW>>2); // Decrement by 1/4
Analog_Input_1_RAW+=read_adc(ADC_READ_ONLY); // Add current value to filtered reading
This example results in a 12 bit result derived from the 10 bit ADC. If the RAW readings are going to be scaled these extra 2 bits dont matter and do nothing to reduce precision of a scaled result.
