Struggling with Timer1 - HELP!!!
picker
PostPosted: Fri Nov 28, 2003 8:44 am     Reply with quote
I am trying to time a 1Hz square wave using TIMER1. The program interrupts on all the interrupts, but I always get a reading of 0 or 1 on the RS232! The way I have it is that the TIMER1 will inc every 1.6uS and that is why I load it with 64535 which is a thousand ticks away from overflow. Then when it overflows I inc a counter which is the lenght of the period in 1.6mS's!. What am I missing?
Here is the code...
#device PIC18F452
#include "C:\Program Files\Picc\ClockCal\ClockCal.h"
long lTemp = 0;
long cnt =0;
long tempcnt=0;
short done=0;
#int_TIMER1
TIMER1_isr() //this will be called every 1000*1.6uS=1.6ms
set_timer1(64535); //1000 * 1.6uS
tempcnt++; //count no. of 1.6ms
#INT_EXT //L_TO_H
EXT_isr()
cnt=tempcnt;
tempcnt=0;
done=true;
#INT_EXT1 //H_TO_L
EXT1_isr()
tempcnt=0;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
port_b_pullups(FALSE);
ext_int_edge(0,L_TO_H);
ext_int_edge(1,H_TO_L);
enable_interrupts(INT_EXT);
enable_interrupts(INT_EXT1);
enable_interrupts(global);
set_timer1(64535);
while (true)
if (done)
printf("%lu \n",tempcnt);
done=false;
//cnt=0;
Humberto
PostPosted: Fri Nov 28, 2003 11:40 am     Reply with quote
#device PIC18F452
long lTemp = 0;
long cnt =0;
long tempcnt=0;
short done=0;
int seconds;
Assuming you are using a 20Mhz Xtal you get:
T1 = 20000000/4=5000000Mhz >> 1/T1 = 0.0000002 s
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);0.0000002 * 8 = 0.0000016 s
1 s / 0.0000016 s = 625000 // times you needs T1 overflows to get 1 sec.
To get 0.1 s >>> 625000 / 10 = 62500
T1 max count = 65536
Loading T1 with 3036 = (65536 - 62500)
will give you an overflow every 0.100 s wich is more comfortable and adecuate to handle time count.
#int_TIMER1
TIMER1_isr()          // this will be called every 0.100 s
  if(tempcnt < 10)
      tempcnt++;     // count no. of 100ms
      done = true;
      tempcnt = 0;
      seconds++;
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
// Just to test your timer1 ONLY
//enable_interrupts(INT_EXT);
//enable_interrupts(INT_EXT1);
set_timer1(3036);
  while (true)
     if (done)
        printf("%u \r\n", seconds);
        done=false;
        set_timer1(3036);  // you must load the hardware timers outside the #INT
Hope this help
Humberto
picker
Thanks...
PostPosted: Fri Nov 28, 2003 1:54 pm     Reply with quote
Thanks...
