Writing to two different I/O at the same time
towpew
PostPosted: Thu Oct 08, 2015 9:41 am     Reply with quote
Hello
I have a C code question.
I have seen in the manual that it is possible to write to different bits at the same time using a struct like this.
//PIC 16F1937
#byte LATA = 0x10C
#bit Abit1 = LATA.1
#bit Abit4 = LATA.4
struct {
          int1 Abit1;
          int1 Abit4;
         } MyAbits;
#byte MyAbits = 0x10C
Now MyAbits pionts to the LATA regsiter and only bit 1 and 4.
This works OK.
But if i want to include I/O from another port say PORTB I cannot include them in the same struct that want work because I can only point MyAbits to 1 memory register.
To clarify, I want to built my own i/o MAP from different i/o's.
MyAbits should be a variable that writes to bit1 and 4 in PORTA and bit 2 and 5 in PORTB and bit 7 and 8 in PORTC.
Does anyone know a way to do this using CCS ?
PostPosted: Thu Oct 08, 2015 10:02 am     Reply with quote
Nothing really to do with CCS. The _processor_ cannot write to two memory addresses at the same time.
towpew
PostPosted: Thu Oct 08, 2015 11:28 am     Reply with quote
Yea Ok i understand that.
But I was curious how the actual processor uses LCD segments on different ports, but it could may be done in the hardware.
PostPosted: Fri Oct 09, 2015 12:09 am     Reply with quote
Totally hardware.
When you use a peripheral, it disables the normal port I/O functions. Things like the LCD, are done from larger latches, connected directly to the pins (except for the switches to disconnect them when normal port I/O is involved). Effectively the pin is no longer portx.y, but just a pin connected to the LCD controller.
PostPosted: Fri Oct 09, 2015 7:07 am     Reply with quote
It uses BCF and BSF statements to clear or set bits in the LCDDATAx
registers, which then control the segment driver pins. Example:
....................       case 1:   // Digit on left side of LCD.
....................         lcd_symbol(segments >> 8, DIGIT8_H);
009C:  MOVFF  segments+1,@@19
00A0:  CLRF   @@1A
00A2:  MOVLB  F
00A4:  BTFSS  x58.4
00A6:  BRA    00A4
00A8:  BTFSS  @@19.7
00AA:  BCF    LCDDATA3.SEG28COM0
00AC:  BTFSC  @@19.7
00AE:  BSF    LCDDATA3.SEG28COM0
00B0:  BTFSS  @@19.6
00B2:  BCF    LCDDATA9.SEG28COM1
00B4:  BTFSC  @@19.6
00B6:  BSF    LCDDATA9.SEG28COM1
00B8:  BTFSS  @@19.5
00BA:  BCF    LCDDATA15.SEG28COM2
00BC:  BTFSC  @@19.5
00BE:  BSF    LCDDATA15.SEG28COM2
Code compiled from:
http://www.ccsinfo.com/forum/viewtopic.php?t=33377&start=11
asmallri
Re: Writing to two different I/O at the same time
PostPosted: Fri Oct 09, 2015 7:26 pm     Reply with quote
towpew wrote:
Hello
//PIC 16F1937
#byte LATA = 0x10C
#bit Abit1 = LATA.1
#bit Abit4 = LATA.4
struct {
          int1 Abit1;
          int1 Abit4;
         } MyAbits;
From a 'C' perspective, you are writing to the structure with a single write but from an assembler perspective, it is not what is happening. It is individually setting and clearing bits as required. If your application specifically required both bits change state simultaneously then it get much more complex on a processor that does not have a separate LAT register for the I/O port in question.
Regards, Andrew
PostPosted: Sat Oct 10, 2015 5:32 am     Reply with quote
There is a 'thread' somewhere here about writing to two ports so try using the 'search' feature. Also the 'flex_LCD' driver does this as well, it's located in the 'code library'.
Be aware that NO method will allow the PIC to write 'simultaneously' to 2 or more I/O ports. Can't be done due to the PIC having 8 bit 'wide' ports.Now depending on processor speed and what the data controls, your program controls it probably will be fine.
In the PC World it's called 'multitasking' where doing 2 or more things very fast makes it 'appear' that both actions occour at the same time( AKA simultaneously).
Jay
PostPosted: Sat Oct 10, 2015 2:02 pm     Reply with quote
This is the thread.
http://www.ccsinfo.com/forum/viewtopic.php?t=18949
That's a very old thread. Nowadays, you would use getenv() to get
the port register addresses, instead of entering them as numbers.
Example:
// Define the bit addresses of the spare pins.
// The addresses shown below are for the 16F877.
#byte PortA = getenv("SFR:PortA")
#byte PortB = getenv("SFR:PortB")
#byte PortC = getenv("SFR:PortC")
#bit RA0 = PortA.0
#bit RA1 = PortA.1
#bit RA4 = PortA.4
#bit RB2 = PortB.2
#bit RB5 = PortB.5
#bit RB7 = PortB.7
#bit RC0 = PortC.0
#bit RC5 = PortC.5
PostPosted: Sun Oct 11, 2015 2:04 am     Reply with quote
One thing that has been ignored through this thread, is the simple question of 'why'?.
Now the systems being pointed to, allow you to 'hide' the separate nature of the pins, to some extent. Great, if this is just for simplicity. However if this is for a 'real' electronic reason (needing signals to switch together), then a deep breath has to be taken, and a big step back made. In such cases, hiding the separate nature can be very dangerous. If (for instance), these are pins controlling devices being switched on/off, then the sequencing may well need to be different, when going from one state to another. So if (perhaps) one low of pins turns on a particular driver, and others turn on another driver the other way, the sequences have to become 'turn off the drivers that are on, and only then turn on the other drivers'. If the PIN identities are hidden in a wrapper, the sequencing becomes that of the wrapper function, implying that the order may well be wrong in one direction, if not the other...
In such systems it becomes vital to control the timings yourself, and work out what order things have to happen to be safe, and ensure the code handles the changes in this sequence in both directions. Get the sequencing wrong when dealing with anything involving power, and nasty things can start to happen.
So big question. Why?.
