PIC24 and set_pwm_duty()
soonc
PostPosted: Mon Sep 14, 2015 7:55 pm     Reply with quote
The code below produces approximate 4kHz with 50:50 duty cycle.
Adjusting duty with: set_pwm_duty(1, n); does change the duty cycle.
It is possible to adjust 50 to 1 but never 50 to 99 if that makes sense!
What do I need to do to get full 1 to 99 duty cycle change ?
Thanks for any feedback.
// compiler V5.049
#include <24FJ128GA306.h>
#use delay(clock=29491200, crystal=7372800)
#pin_select OC1 = PIN_D0
void SetUpPWM1()
   setup_timer3(TMR_INTERNAL | TMR_DIV_BY_1, 3674);
   setup_compare(1, COMPARE_PWM_CENTER | COMPARE_TIMER3 | COMPARE_SYNCHRONIZE | COMPARE_TRIG_SYNC_TIMER3);
   set_compare_time(1, 1819, 1855);
   set_pwm_duty(1,900); // set 50% duty
soonc
Problem Solved
PostPosted: Sun Oct 04, 2015 10:52 am     Reply with quote
I found the #use PWM after upgrading to Compiler V 5.050
#use PWM ( PWM1, OUTPUT=PIN_D0, TIMER=3, FREQUENCY=4000, PWM_ON)
Then use:
set_pwm_duty(1, value);
For my setup the duty cycle can now be fully adjusted.
