12f629 adding a long variable causes program to hang
johnl
PostPosted: Tue Sep 01, 2015 9:25 am     Reply with quote
This code runs correctly. If a long variable is introduced, it hangs. Compiler is pcm 4.121
#include <12f629.h>
#fuses MCLR, PROTECT, NOWDT,INTRC_IO,PUT ,NOBROWNOUT
#define SENSOR    Pin_A5
#define LED       Pin_A4
#define BEACON    Pin_A2
#define LEAKMODEENABLE  Pin_A0
#define LED_ON    output_low(LED)
#define LED_OFF   output_high(LED)
#define BEACON_ON  output_high(BEACON)
#define BEACON_OFF output_low(BEACON)
#define THRESHOLD  240
#define set_options(value)   {#ASM         \
                              MOVLW  value \
                              OPTION       \
                              #ENDASM}
#byte PORTA = 5
#byte WPU = 0x95
long junk;   //Comment this out and the last line  and all works fine;
             //      otherwise the program hangs.
unsigned char Hit;
unsigned char j;
unsigned char i;
unsigned char Mode = 1;   //1 = normal operation, 0 = light leak detect mode.
void Flash_Beacon(void)
  { BEACON_ON;
    if (Mode)
        delay_ms(20);    // longer flash when not in light leak mode
        delay_us(500);    // shorter flash when in light leak mode
    BEACON_OFF;
void Leak_detect()
    Hit=0;
    for (i=0;i<255;i++)
      LED_ON;
     delay_cycles(5);
     LED_OFF;
     if (   !input(PIN_A5)  )  { Hit++;}  //
     delay_cycles (2);
void Send_and_receive()
 Hit=0;
 for (i=0;i<255;i++)
      LED_ON;
     delay_cycles(5);
     LED_OFF;
     else Hit=0;
     delay_cycles(2);
  WPU = 1;   //A0 weak pullup on
  set_tris_a(0b00100001);   //A0 input to detect Mode choice
  LED_OFF;  BEACON_OFF;// everything off
  set_options(0x80);
  Mode = input(PIN_A0) ;    // 1 = normal, 0 = leak detect mode
  set_tris_a(0b00100000); //turn off input on A0
 for (j=0; j<(2+Mode); j++)  // 3 flashes for normal mode , 2 for light leak mode
  {BEACON_ON; delay_ms(2);BEACON_OFF; delay_ms(400);
 delay_ms(3000);
 while(1){
  BEACON_OFF;
  if (Mode)
     Send_and_receive();
   Leak_detect();
  delay_ms(300);
  if (Hit>THRESHOLD*Mode)
         Flash_Beacon();
 delay_ms(300);
 junk = junk^1;
johnl
PostPosted: Tue Sep 01, 2015 9:29 am     Reply with quote
Just figured it out. Need to use "int16" instead of "long"
Spoke too soon. I changed the variable "i" to int16 and the program hung.
Update: I had the programming range set to a fixed number in MPLAB. Changing to "Auto" fixed the issue.
Why does MPLAB report Programming/Verify complete when it is not true?
PostPosted: Tue Sep 01, 2015 11:06 am     Reply with quote
Because it has successfully programmed the range you have told it to program.....
asmboy
PostPosted: Tue Sep 01, 2015 11:44 am     Reply with quote
one other observation:
you use set_tris to declare the I/O pin state for port A
S O . . . .
it is a REALLY good practice to have executed
a
#USE FAST_IO()
declaration for porta before doing the first SET_TRIS operation
