Porting C-Code from GCC Compiler to CCS help
Jerry I
PostPosted: Tue Aug 25, 2015 6:56 pm     Reply with quote
HI,
I found a serial protocol C-code example from Circuit Cellar example and I wanted to try to port the code to run on the CCS C-compiler. The software is Arduino compatible.
The start of errors are in 2 structures. I do not know how to handle.
Both structures have a callback function (described in comments) below.
The error occurs at this point. The error is -> Unknown Type
void (*cback)(uint8_t, uint8_t, uint8_t); // callback function
void (*func)(uint8_t);                // callback for new stable state
Is there a way to handle this in CCS C-Compiler?
Thanks for any help.
Jerry
struct vtimer {                           // one per timer
  uint16_t rtics;                         // remaining clock tics
  uint16_t otics;                         // original tic count (for repeating events)
  struct vtimer *next;                    // next in list
  uint8_t tid;                            // timer ID (1 - 127)
  uint8_t tstats;                         // timer status
  uint8_t remain;                         // timeouts remaining
  uint8_t uident;                         // user identification
struct dbounce {
  volatile uint8_t *input;              // which PIN the switch is on
  uint8_t pmask;                        // which bit (0 - 7) as a mask
  uint8_t nread;                        // number of consecutive reads that make it stable
  uint8_t trans;                        // which transitions we care about
  uint8_t swstat;                       // switch status (callback pending, stable)
  uint8_t rcount;                       // number of consecutive reads we've done
  uint8_t last_rd;                      // last value read
  uint8_t last_ok;                      // last stable value
PostPosted: Tue Aug 25, 2015 9:10 pm     Reply with quote
I added this include file and it compiled with no errors or warnings:
#include <stdint.h>
This is with CCS vs. 5.048.
