ercarlitosg
Problem with wrapping lcd_putc |
Posted: Wed Jul 29, 2015 4:51 am |
I am using now a PIC16F877A and the flex_lcd driver. I am using the lcd to display a text when received one of the 14 commands that I receive from the serial port. Parsing and receiving the code isn't a problem, it works prefect.
The problem is displaying the text in the LCD. In the 14 commands I have to run some functions (disable keyboard and serial input, show the text, delay 3 seconds, reset serial input variables and display another text). Copying and pasting this into every command section is a monstrous task!!.
So I decided to make a wrapper to the run these functions. Here it is
void muestra_mensaje(char data) {
disable_input();
/* Limpia pantalla */
lcd_putc("\f");
lcd_putc(data);
send_ok();
The problem is in lcd_putc(data);. It doesn't display the message.
Thanks for your answers |
Posted: Wed Jul 29, 2015 7:47 am |
Show us how you call the function. Post some code, including variable
declarations and initializations, that calls muestra_mensaje().
My suspicion is that you think 'char data' is a pointer and that somehow
lcd_putc() will work with a string pointer inside muestra_mensaje(). |
Posted: Wed Jul 29, 2015 8:07 am |
As written, it'll only display one character. The single character 'data'.
I'd guess he actually wants to pass it a char array (string):
void muestra_mensaje(char * data)
disable_input();
printf(lcd_putc,"\f%s",data);
send_ok();
ercarlitosg
Posted: Sat Aug 22, 2015 4:59 am |
Thanks for your answers.
Here is some examples of how I call that function:
muestra_mensaje("HI");
muestra_mensaje("\nHI");
So that code doesn't work if I don't want to clear the screen.
Thanks |
Posted: Sat Aug 22, 2015 1:45 pm |
Quote: | So that code doesn't work if I don't want to clear the screen. |
But you can edit Ttelmah's code and remove the \f from the printf
so it becomes this:
printf(lcd_putc,"%s",data); |
Also, you need to add the line shown in bold below, or it won't compile.
With the added #device statement, it displays this in MPLAB vs. 8.92 simulator:
Test program:
Quote: |
#include <18F4620.h>
#device PASS_STRINGS=IN_RAM
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
void lcd_putc(char c)
putc(c);
// disable_input();
// send_ok();
while(TRUE);
Posted: Sat Aug 22, 2015 1:57 pm |
Yes. I only added the \f, because he had it in his original code..... |
ercarlitosg
Posted: Thu Aug 27, 2015 11:58 am |
Sorry for my bad response. I don't know why I put that.
I refer that the code didn't worked with a constant string, but with the last response of PCM programmer It worked.
Many thanks for your help and sorry for my expression. |
