Blank disassembly list depending on code
E_Blue
PostPosted: Wed Aug 19, 2015 10:07 am     Reply with quote
I'm using MPLAB IDE v8.92 and CCS v5.048 to generate code for a PIC18F67J50.
I get three results depending on the code, even a single Enter can change the result.
1)I get the full disassembly list code.
2)I get one blank line.
3)I get one line with a single GOTO @cinit1
I search in this forum and see that happen old time ago with an early version of CCS compiler.
https://www.ccsinfo.com/forum/viewtopic.php?p=59447
This bug was solved or still alive until nowadays. Question
There's any considerations to take to work around this bug?
Electric Blue
PostPosted: Thu Aug 20, 2015 12:12 am     Reply with quote
What are your Project / Build Options settings in MPLAB ? In the Debug
section, if I select None or Expanded COD format and compile, it says
"Failed to Load" and gives me a blank Disassembly Listing in the View
menu. If you use COFF format, it should work OK.
E_Blue
PostPosted: Thu Aug 20, 2015 6:04 am     Reply with quote
Yes I'm using COFF format.
The result changes according to the code.
Electric Blue
PostPosted: Thu Aug 20, 2015 7:34 am     Reply with quote
I must admit, I have never seen this.
However I always compile _outside_ MPLAB. Don't know why, but it seems much easier to have proper control of the compile process, being confident that MPLAB will not change things, and seeing the compiler error messages directly, rather than having an extra layer that may hide things.
Try the experiment, with code that shows the problem, of compiling this outside. I'd guess there is going to be something like a warning being generated, and it is this that hiccups MPLAB....
E_Blue
PostPosted: Thu Aug 20, 2015 8:09 am     Reply with quote
How do you compile outside the MPLAB?
Are you using CCS IDE?
I use MPLAB because I mostly compile to debug the program.
Electric Blue
PostPosted: Thu Aug 20, 2015 8:26 am     Reply with quote
If you have the IDE yes, you can use this, otherwise just use a command line compile.
