Micro_Guy
Image Location on 128x64 GLD Display |
Posted: Wed Aug 19, 2015 11:17 pm |
Hi Guys,
Typically when we want to display an image onto a 128x64 GLCD the byte array size is 64X16. To save space, I have a small image byte array 22x3. I would like to know how I can control where on the 128X64 the image is displayed (how to display it in the top left corner/ top right corner/ middle of screen etc.) I'm using the CCS HDM64GS12.c and graphics.c libraries...
Below is the code which writes the byte array onto the GLCD.
void glcd_imagem(int8 imagem);
const int8 imagem_1[22][3] = {
0x01, 0xFC, 0x00,
0x03, 0x03, 0x00,
0x04, 0x01, 0x00,
0x08, 0x00, 0x80,
0x08, 0x00, 0x80,
0x08, 0x00, 0x00,
0x08, 0x10, 0x00,
0x09, 0xA4, 0x80,
0x09, 0x5C, 0x80,
0x04, 0x09, 0x80,
0x06, 0x01, 0x00,
0x02, 0x02, 0x00,
0x01, 0x42, 0x00,
0x01, 0x04, 0x00,
0x01, 0xFC, 0x00,
0x01, 0x04, 0x00,
0x01, 0xFC, 0x00,
0x01, 0xFC, 0x00,
0x00, 0xD8, 0x00,
0x00, 0x20, 0x00,
0x00, 0x00, 0x00,
0x00, 0x00, 0x00,
0x00, 0x00, 0x00
void glcd_imagem(int8 imagem){
char i,j;
signed char k;
if(imagem==1){
for( i = 0 ; i < 22 ; i++ ){
for( j = 0 ; j < 3 ; j++){
for(k=100;k>-1;k--){
if( bit_test(imagem_1[i][j] ,100-k ))
glcd_pixel( j*8+k,i, ON );
After playing with the code above I've discovered that by changing the 100 value, the image is shifted left or right. However, I do not understand why (help here is also greatly appreciated).
Can someone help explain what the the code is actually doing and how i can adjust the image up and down...
Thanks in Advance |
Posted: Wed Aug 19, 2015 11:42 pm |
Add int8 parameters of x, y to your glcd_imagem() function declaration.
Then inside that function, modify your call to glcd_pixel() to this:
Code: | glcd_pixel( (j*8+k) +x, i +y , ON ); |
This modification adds the x, y offset from the origin to all pixel draws. |
Micro_Guy
Posted: Wed Aug 19, 2015 11:59 pm |
Sucess!!!
Thanks PCM Programmer!!!
Do you think you could shine some insight as to what's going on with the following code.
if(imagem==1){
for( i = 0 ; i < 64 ; i ++ ){
for( j = 0 ; j < 16 ; j ++){
for(k=7;k>-1;k--){
if( bit_test(imagem_1[i][j] ,7-k ))
I'm fairly new to programming and would like to better understand arrays and how they can be manipulated. I want to actually know what's going on instead of just manipulating code.
Thanks |
Posted: Thu Aug 20, 2015 12:13 am |
I don't know. I hoped you were going to explain it to me.  |
