art
How to receive 3 character from PC and send it to Output |
Posted: Thu May 21, 2015 9:45 am |
I am using rs232 (hardware on pic 18f452) to receive single character commands from a pc.
This works very well but I would like this to work with simple strings if possible so I can change my single character commands to 3 characters and the output can work when receive 3 characters.
Any suggestions on how to implement simple strings would be very welcome.
#include <18F452.h>
#include <string.h>
#int_rb
void detect_rb_change() {
while(input(PIN_B0)) ;
delay_ms(25);
char cmd ;
byte j;
for (j=1;j<=250;++j)
byte i;
for (i=1;i<=250;++i)
enable_interrupts(int_rb);
enable_interrupts(global);
printf("\rPress 0,1,2,3,4,5 : %c \n",cmd);
cmd=getc();
if(cmd=='A')
output_B(0b00000000);
if(cmd=='B')
output_B(0b00000001);
if(cmd=='C')
output_B(0b00000010);
Mike Walne
Posted: Thu May 21, 2015 11:24 am |
Try the CCS sample folder.
(EX_STR.C for starters.)
Mike |
Posted: Thu May 21, 2015 1:37 pm |
and also get rid of the delay in the INT_RB handler.
This will mean that the serial _will_ at times have overloaded, and will never recover (since you don't have 'ERRORS' in the RS232 declaration.
If you need a delay to do something, then set a flag, and delay in the external code, with the interrupts left running. |
Posted: Fri May 22, 2015 1:00 am |
Ttelmah wrote: | and also get rid of the delay in the INT_RB handler | Same applies to the while loop which loops as long as the button is pressed. Even a user pressing the button very short will take 100ms, that is very long for a processor to do nothing. Again, serial data will get lost.
The same effect can be achieved by setting the interrupt to activate on the other edge. Then, when you enter the interrupt again you know this is because the user let the button go.
Code: | byte j;
byte i;
{ | This part of the code makes the program repeat itself. After 250 * 250 = 62,500 times the program will stop. Is that what you want? If yes, then using an int16 that runs from 1 to 62,500 is much clearer about your intentions.
My guess is you intend your program to loop forever, then using a while(true) command is the right choice. |
art
Posted: Fri May 22, 2015 5:38 am |
Hi Ttelmah,
Thank you, i will use while(true) command |
