ercarlitosg
Having trouble with ANSI C code in CCS |
Posted: Sun May 10, 2015 3:55 am |
I am having trouble with an ansi c code to encrypt/decrypt aes. The code can be found in https://github.com/kokke/tiny-AES128-C . I got it compiled in computer using GCC, but I am having lots of problems in CCS C and when I try to fix I get in the aes test failure. Here are the problems:
In file aes.h, I get error here:
Code: | void AES128_CBC_encrypt_buffer(uint8_t* output, uint8_t* input, uint32_t length, const uint8_t* key, const uint8_t* iv); |
The error is in the last two variables with const. My patch is to remove the const modifier:
Code: | void AES128_CBC_encrypt_buffer (uint8_t* output, uint8_t* input, uint32_t length, uint8_t* key, uint8_t* iv); |
Then in aes. c I get errors in:
Function ShiftRows
When rotating rows to the left in all the code like this:
Code: | (*state)[0][1] = (*state)[1][1]; |
I get error in this part , getting LVALUE error.
I fix it with the next code:
Code: | uint8_t second_row_value = 1;
// Rotate first row 1 columns to right
temp=(*state)[3][1];
(*state)[3][second_row_value]=(*state)[2][1];
(*state)[2][second_row_value]=(*state)[1][1];
(*state)[1][second_row_value]=(*state)[0][1];
(*state)[0][second_row_value]=temp; |
Also I am having with the type intptr_t which ccs doesn't recognize. What type could I replace it?
I am using ccs 5.025
Thanks for helping |
Joined: 01 Jul 2010 Posts: 9510 Location: Greensville,Ontario
Posted: Sun May 10, 2015 5:09 am |
You need to understand that CCS C is NOT ANSI C. You can't just grab an ANSI C program or function and assume it will work in CCS C thinking that C is C. Since V2.534 I've understood this especially since I've never coded anything in 'ANSI C' and have been programming since '74.
Your first error deals with the fact that in CCS C 'const' is a reserved word, hence it must be used in a specific way. Just consult the manual and you'll see how it's to be used. Every language has 'reserved' words,syntax, limits, etc. That's why is important to read the manual,look at the CCS supplied examples as well, There is a LOT of knowledge i them !!
jay |
Posted: Sun May 10, 2015 10:18 am |
Have you tried adding #device ANSI, as shown below ? That will fix some
of the errors:
#include <18F4620.h>
#device ANSI // *** Add this line
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=4M)
#use rs232(baud=9600, UART1, ERRORS) |
Quote: | The error is in the last two variables with const. My patch is to remove the const modifier: |
#device ANSI will fix that one. It will make 'const' mean read-only
instead of "put it in ROM".
Quote: | Then in aes. c I get errors in:
Function ShiftRows
#device ANSI won't fixt that one. |
Posted: Sun May 10, 2015 12:19 pm |
typedef int16 *intptr_t;
CCS with the ANSI declaration, is 99% compatible with ANSI-C90. However the intptr types, were only added with ANSI-99. A lot later....
'ANSI', covers (now) several versions, with their own oddities, and extras.
CCS have made the compiler get close to matching the original version (as described by K&R in the second edition of the 'C programming language', with some later features, but you still need to tidy up such 'later' features. |
ercarlitosg
Posted: Mon May 11, 2015 1:45 am |
Thanks for your help
Do you know how to fix this?
This works well on gcc compiler. |
I just compiled the code. Built a function to call it all with the CCS setups, and ANSI mode selected. Added the typedef for intptr_t, and made just one change to the code. Wherever *state is used, I replaced this with an explicit cast, so *(state_t *)state. I've noticed before that CCS sometimes seems to 'forget' what a pointer actually points 'to', when it to something like an array.
Obviously changed the main so it never exits, and changed it's declaration to void.
Two lines give warnings:
tempa[0] = tempa[0] ^ Rcon[i/Nk];
Which a simple bracket fixes:
tempa[0] = tempa[0] ^ (Rcon[i/Nk]);
and one logic test:
else if (Nk > 6 && i % Nk == 4)
Which gives a warning 'always FALSE'. Nk, is #defined as '4', so the compiler is right, this _will_ always return FALSE.
Whether it runs is another matter....
I'd suspect the main problem will be the functions to rotate the arrays. Honestly better to rewrite these perhaps using memcpy, indirect pointer accesses like this are very inefficient in the PIC..... |
ercarlitosg
Posted: Thu May 14, 2015 5:45 am |
Ttelmah wrote: | I just compiled the code. Built a function to call it all with the CCS setups, and ANSI mode selected. Added the typedef for intptr_t, and made just one change to the code. Wherever *state is used, I replaced this with an explicit cast, so *(state_t *)state. I've noticed before that CCS sometimes seems to 'forget' what a pointer actually points 'to', when it to something like an array.
and one logic test:
Thanks, but I moved to other implementation and this works quite well.
Many Thanks |
