I can't enable Slave Select pin on 16F1508[SOLVED]
rikotech8
PostPosted: Sat May 09, 2015 1:03 pm     Reply with quote
Hello everyone.
I am trying to run SPI interface on 16F1508 but I have problem with the hardware SS(Slave Select) pin of the SPI. Scoped the signals on SCLK SDO are fine but SS (PIN_C6) isn't moving at all. I tried many different configurations but no success at the end. Here is the code:
#include <16F1508.h>
#FUSES INTRC_IO, NOWDT, PUT, NOMCLR, NOPROTECT, NOBROWNOUT, NOCLKOUT, NOIESO, NOFCMEN, NOWRT, NOLPBOR, NODEBUG, NOLVP
#USE delay(internal = 16M)
#use spi(FORCE_HW, BITS=8, ENABLE=PIN_C6, ENABLE_ACTIVE=0)
#include "NRF24L01.c"
setup_oscillator(OSC_16MHZ);
setup_spi(SPI_MASTER | SPI_SCK_IDLE_LOW | SPI_XMIT_L_TO_H | SPI_SS_C6);
      spi_write(0xAA);
      delay_us(100);
Any help would be much appreciated!
A person who never made a mistake never tried anything new.
PostPosted: Sat May 09, 2015 2:16 pm     Reply with quote
It's an input pin on a hardware SPI slave. The hardware master doesn't
use it.
You need to use spi_xfer, not spi_write.
There are two _separate_ ways of driving the SPI with CCS. Spi_read and spi_write are for use with the old setup_spi method, and only gives simple operation (no slave select). For #use spi, you must use spi_xfer, which can then control the select line.
If you look at the manual, you will find that setup_spi refers you to spi_read and spi_write, while #use spi refers you to spi_xfer.
You must not mix the two methods.
#use spi, can control the pin as an output for the master device.
Get rid of the setup_spi line, and use spi_xfer to send, and the code can then control this line.
On the master device, the output, can be any pin (doesn't have to be the slave select pin).
rikotech8
PostPosted: Sun May 10, 2015 2:58 am     Reply with quote
Thank you guys for replies.
Yes it works that way, but the BAUD rate is quite slower when I am not using this line, and I can't figure out why.
With this configuration:
      spi_xfer(0xAA);
      delay_us(10);
I send one byte for 25uS.
But when I use the setup_spi line in my code I get faster bit rate:
      spi_xfer(0xAA);
      delay_us(10);
Now I send one byte for approximately 2uS.
Much faster with second piece of code. Could you please shed some light.
PostPosted: Sun May 10, 2015 6:48 am     Reply with quote
#use spi, allows you to specify the baud....
rikotech8
PostPosted: Sun May 10, 2015 7:18 am     Reply with quote
BAUD=n
Target bits per second, default is as fast as possible.
PostPosted: Sun May 10, 2015 12:21 pm     Reply with quote
If you believe that, you will believe anything..... Smile
You'll find it does go as fast as possible for software SPI, but for hardware, unless you specify the rate, it doesn't configure things like the prescaler.
rikotech8
PostPosted: Sun May 10, 2015 1:23 pm     Reply with quote
Thx a lot T
