fftftw
24FV16KA301 cannot blink |
Posted: Thu Apr 23, 2015 10:37 am |
Hi
I have programmed several 16 bit microchips with CCS before, but I cannot get anything out of this 24FV16KA301. I made some example code in the CCS C Compiler (below) and am using it in MPLAB IDE v8.92, with a pickit3 for programming. I checked all the connections; the microcontroller is getting 5V and ground, MCLR, PGD, and PGC are connected to the ISCP 1 pins correctly. I have the correct device selected in MPLAB. And I have CCS C Compiler selected under Select Language Toolsuite. I also have the 24bit version of CCS and can see the header file located in the PICC\Devices directory. I have tried blinking on many different pins on banks A and B, but still the oscilloscope shows nothing on the pins. The program compiles and programming is verified.
Any suggestions are very much appreciated!
#include <24FV16KA301.h>
#FUSES CKSFSM //Clock Switching is enabled, fail Safe clock monitor is enabled
#device ICSP=1
#use delay(internal=8MHz)
#use FIXED_IO( A_outputs=PIN_A4 )
#define LED PIN_A4
#define DELAY 1000
//Example blinking LED program
while(true)
output_low(LED);
delay_ms(DELAY);
output_high(LED);
delay_ms(DELAY);
jeremiah
Posted: Thu Apr 23, 2015 1:36 pm |
Either try a different pin, or you need to go back and add more FUSES to your program. A4 is on a special pin that doesn't default to digital like most of the pins do. There is a FUSES configuration that sets it to digital.
Additionally, you really need to go back through and add more FUSES anyways. Unrelated to your current problem probably, but there are two oscillator fuses that should be specified or you can risk the defaults not running your clock at the correct speed.
If you were using the CCS IDE, I would suggest using the Valid Fuses (v4 compiler) or Configuration Bits (v5) button to see all the options and go from there comparing them to the data sheet. Since you are using MPLAB, I don't know the normal way of getting that outside just looking at the fuses.txt file in the install directory and comparing to the data sheet, but that is a lot more work.
EDIT: Also, no need for fixed_io. The compiler will set the TRIS for you when you call output_low/output_high/output_toggle/etc. |
fftftw
Posted: Thu Apr 23, 2015 2:05 pm |
Thank you for the reply! I will use CCS C Compiler to find fuses and add them to my code. However, I did try using a bunch of different pins, from banks A and B.
The only reason I use MPLAB is because I could not get the pickit3 to connect to the C Compiler. So I just copy the code over to MPLAB after using the CCS project wizard. |
Joined: 01 Jul 2010 Posts: 9503 Location: Greensville,Ontario
Posted: Thu Apr 23, 2015 2:21 pm |
hmmm.. have you set mplab 'build configuration' to 'release' instead of the default of 'debug'?
That one will nail you !!!
fftftw
Posted: Thu Apr 23, 2015 2:26 pm |
Hi Jay
No. When I go to Project>>Build Configurations it says "(No Build Configurations)" and it is grayed out.
And just looking at another project where I use a PIC16F1827 the Build Configuration is the same way. Also, I didn't have to add any fuses either. Hmmm, I guess that was just a much simpler microcontroller. |
Posted: Thu Apr 23, 2015 2:51 pm |
Quote: | When I go to Project>>Build Configurations it says "(No Build Configurations)" and it is grayed out. |
See this post. It tells how to fix it, if Build Configuration (Release / Debug)
is grayed out in MPLAB vs. 8.92:
http://www.ccsinfo.com/forum/viewtopic.php?t=46950&start=7 |
fftftw
Posted: Fri Apr 24, 2015 8:52 am |
Thank you for the suggestions!
I tried adding #fuses SOSC_DIGITAL and tried using other pins on bank B. But still no output. I also tried setting the Build Configuration to Release (after installing the plug-in it was no longer grayed out), and still nothing.
I tried the same code with a 16F1827 (just switched the #include and Select Device in MPLAB) and it works.
Code: | #include <24FV16KA301.h>
#fuses SOSC_DIGITAL //SOSC pins set for Digital mode for use with external clock or Digital I/O
#device ICSP=1
#use FIXED_IO( B_outputs=PIN_B4 )
#define LED PIN_B4
#define DELAY 1000
while(true)
output_low(LED);
delay_ms(DELAY);
output_high(LED);
delay_ms(DELAY);
Posted: Fri Apr 24, 2015 10:37 am |
1) What compiler version?.
2) Get rid of the fixed IO. It's a complexity that is not wanted at this point.
3) The instinct is that the chip may not be running at all. That it behaves the same on other pins suggests this.
Try explicitly selecting FRC, NOWDT, NOMCLR.
This may be one of the chips where the watchdog is enabled by default. As such it might be starting, setting the line low, and then restarting. It'd then not seem to be running. There are a number of newer chips where this is the case, hence it is always worth trying disabling it. |
fftftw
Posted: Fri Apr 24, 2015 10:59 am |
Compiler version 5.026
No change after removing the fixed IO.
I have these fuses:
#FUSES NOWDT
#fuses FRC
#fuses NOMCLR
And still nothing |
fftftw
Posted: Fri Apr 24, 2015 11:09 am |
Actually #fuses NOMCLR gives the following error:
The following memory regions failed to program correctly:
Configuration Memory
Address: 00f8000c Expected Value: 0000007c Received Value: 000000fc
Programming failed |
fftftw
Posted: Fri Apr 24, 2015 11:53 am |
Well this is embarrassing. I just changed the chip and it fixed it. Its odd because changing the chip was one of the first things I tried, but I must have broken 2 of them. I wish the programmer would throw some kind of error if the chip is burned out.
Thanks everyone for your help! |
Posted: Fri Apr 24, 2015 2:08 pm |
Or, there is a batch problem.....
I've had large groups of faulty chips (had to return over 10000 at one point...). It'd be worth reading the chip ID number on the working one and the faulty ones and see if there is a difference. Other possibility is that something is not erasing properly (one poster here had a problem that if he selected a particular clock setting, a chip became 'unrecoverable', and had to be replaced by Microchip). |
ELCouz
Posted: Fri Apr 24, 2015 2:10 pm |
Just to add...
don't rely on the internal word for delays that automatically activate the internal oscillator... had this kind of problem in the past with CCS v4
Just use FRC fuses it's safer... _________________ Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy! |
jeremiah
Posted: Fri Apr 24, 2015 2:20 pm |
You also want to specify the clock circuit fuse (HS,XT,EC,NOPR) as NOPR. Almost all PIC24s have two oscillator fuses:
HS,XT,EC,NOPR - specifies the circuit to use
PR,FRC,LPRC,PR_PLL, etc. - controls the clock mux |
ELCouz
Posted: Fri Apr 24, 2015 2:46 pm |
jeremiah wrote: | You also want to specify the clock circuit fuse (HS,XT,EC,NOPR) as NOPR. Almost all PIC24s have two oscillator fuses:
He's right!
Got bite by that the first time I've tried PIC24 platform...
Datasheet is your friend too ..specially when exploring new stuff ;) _________________ Regards,
Laurent
