ELCouz
EEPROM 8-bit or 16-bit? |
Posted: Wed Apr 08, 2015 3:37 pm |
I've been trying devices in the 24-bit opcode world...
On the 30F6014A, I have access to 4K of internal EEPROM.
I'm writing a function to write and read unsigned int32 directly to the EEPROM.
However from the CCS help file it's not very clear what type of int I expect to receive.
Quote: |
Relevant Functions:
(8 bit or 16 bit depending on the device)
read_eeprom(address)
Reads the data EEPROM memory location
write_eeprom(address, value)
Erases and writes value to data EEPROM location address.
read_eeprom(address, [N])
Reads N bytes of data EEPROM starting at memory location address. The maximum return size is int64.
read_eeprom(address, [variable])
Reads from EEPROM to fill variable starting at address
read_eeprom(address, pointer, N)
Reads N bytes, starting at address, to pointer
Writes value to EEPROM address
write_eeprom(address, pointer, N)
Writes N bytes to address from pointer
Microchip datasheet talk about transferring data per chunk of words (so int16 right?)
I've always dealt with writes one byte at time on the PIC16/18 series. _________________ Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy! |
asmboy
Posted: Wed Apr 08, 2015 5:38 pm |
although the 30F part in question can allow values less than 16 bits - for the purposes of the data sheet, a WORD for the EEPROM is still 16 bits ....
So what do you think when you read page 57 of the datasheet? |
bkamen
Posted: Wed Apr 08, 2015 10:29 pm |
Ultimately, it comes down to the datasize of the storage medium.
YES, you are still writing bytes.
One method I like it to put my entire config into a structure.
This can be a mix of anything. uint8, int16, floats, doesn't matter.
then I create a pointer to the structure when saving and step through the bytes of the struct and save/load them to/from the EEPROM/Flash.
Works swell.
Posted: Thu Apr 09, 2015 1:14 am |
The EEPROM functions on the 30F chips read and write 16bit words, not bytes.
If you look at the example. ex_intee.c, you will see them simply test for the compiler version:
#if defined(__PCD__)
// dsPIC30F/dsPIC33F/PIC24 internal eeprom is 16bit wide
typedef int16 INTEE;
#else
typedef int8 INTEE;
and they then declare the value they are reading and writing as "INTEE value".
The manual is wrong, in that while it says that 'read_eeprom' returns either 8 or 16bit, on the write_eeprom function, it says that the value is 8bit. However it isn't. The function writes 16bit lumps on these larger PIC's.
So:
void weeprom(unsigned int16 addr, unsigned int16 val)
write_eeprom(addr,val);
Writes a 16bit value to the EEPROM. |
