unable to restart my loop from zero again
anilmanisingh
PostPosted: Wed Apr 08, 2015 3:47 am     Reply with quote
Hello Everyone.
I want my program to start from LED One again .
But I am stuck after the switch is incremented to 3.
#include <18F4520.h>
#fuses INTRC_IO, BROWNOUT, PUT, NOWDT
#use delay(clock=4M)
#define BUTTON_PIN   PIN_B0 // This pin must have a pull-up.
#define DEBOUNCE_PERIOD_IN_MS  10
#define DEBOUNCE_COUNT  2
void wait_for_keypress(void);
char count;
// First, wait for the button to be released.   With the debounce
// values as given above, the button must be in the "up" state
// for two consecutive readings, spaced 10 ms apart.
count = 0;
   if(input(BUTTON_PIN) == 1)
      count++;
      count = 0;
   if(count == DEBOUNCE_COUNT)
   delay_ms(DEBOUNCE_PERIOD_IN_MS);
// Now that the button is up, wait until the user presses it.
// In order for the keypress to be considered valid, based
// on the debounce values listed at the beginning of the
// program, the button must be held down for two consecutive
// readings, spaced 10 ms apart.
count = 0;
   if(input(BUTTON_PIN) == 0)
      count++;
      count = 0;
int8 count;
port_b_pullups(TRUE);
count = 0;
   wait_for_keypress();
   count++;
   if (count==1)
   output_high(PIN_C1);
   output_low(PIN_C1);
   else if (count==2)
   output_high(PIN_C2);
   output_low(PIN_C2);
   else if (count==3)
   output_high(PIN_C3);
   output_low(PIN_C3);
alan
PostPosted: Wed Apr 08, 2015 4:02 am     Reply with quote
 if (count > 3) count = 1;
anilmanisingh
PostPosted: Wed Apr 08, 2015 4:24 am     Reply with quote
Thanks Alan
Problem Solved
