FUSES identification...
ELCouz
PostPosted: Sun Apr 05, 2015 4:08 pm     Reply with quote
Do someone knows where to find descriptions of fuses for a device?
Every time I check some shady name fuses, CCS have made their own fuses name and doesn't match the Microchip datasheet configuration names.
Try finding BORRES (by logic is something like Brown-out Reset) in the datasheet...
Like SSSSS ... huh that's a good one!
On device header you have something like:
#device DSPIC30F6014A
#nolist
//////// Program memory: 49152x24  Data RAM: 8192  Stack: 31
//////// I/O: 76   Analog Pins: 16
//////// Data EEPROM: 4096
//////// Fuses: LP,FRC,LPRC,XLT,HS,XT,ER_IO,ER,EC,EC_IO,FRC_PLL4,FRC_PLL16
//////// Fuses: XT_PLL4,XT_PLL8,XT_PLL16,FRC_PLL8,EC_PLL4,EC_PLL8,EC_PLL16
//////// Fuses: HS2_PLL4,HS2_PLL8,HS2_PLL16,HS3_PLL4,HS3_PLL8,HS3_PLL16
//////// Fuses: CKSFSM,CKSNOFSM,NOCKSFSM,WPSB1,WPSB2,WPSB3,WPSB4,WPSB5,WPSB6
//////// Fuses: WPSB7,WPSB8,WPSB9,WPSB10,WPSB11,WPSB12,WPSB13,WPSB14,WPSB15
//////// Fuses: WPSB16,WPSA1,WPSA8,WPSA64,WPSA512,NOWDT,WDT,NOPUT,PUT4,PUT16
//////// Fuses: PUT64,BORV45,BORV42,BORV27,BORRES,NOBROWNOUT,BROWNOUT,NOMCLR
//////// Fuses: MCLR,WRTB,NOWRTB,BSSHL,BSSHM,BSSHS,BSSSL,BSSSM,BSSSS,NOBSS
//////// Fuses: EBS,NOEBS,RBSL,RBSM,RBSS,NORBS,WRTSS,NOWRTSS,SSSHL,SSSHM
//////// Fuses: SSSHS,SSSSL,SSSSM,SSSSS,NOSSS,ESS,NOESS,RSS4096,RSS2048
//////// Fuses: RSS256,NORSS,WRT,NOWRT,PROTECT_HIGH,PROTECT,NOPROTECT,ICSP4
//////// Fuses: ICSP3,ICSP2,ICSP1,DEBUG,NODEBUG
I know most of them (they repeat on many devices) but some are specific to a device.
CCS Help file is no help too!
Thank you very much!
Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
PostPosted: Sun Apr 05, 2015 4:58 pm     Reply with quote
'old school' detective way is to see what the 'fuse' is in binary and which register, then look at the PIC's datasheet to decide what Microchip calls it.
Why CCS doesn't follow Microchips naming ?? Maybe 'trademark' infringement??
one of life's 'challenges' ??
Jay
dyeatman
PostPosted: Sun Apr 05, 2015 5:02 pm     Reply with quote
Did you look in the fuses.txt file in the compiler directory.
Google and Forum Search are some of your best tools!!!!
ELCouz
PostPosted: Sun Apr 05, 2015 5:46 pm     Reply with quote
Thank You!!!
Regards,
Laurent
