how running 18F26K22 to 64MHZ internal?
cvargcal
PostPosted: Sat Apr 04, 2015 9:46 pm     Reply with quote
Someone can help me with this doubt:
I want to have the max speed
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOPLLEN                  //4X HW PLL disabled, 4X PLL enabled in software
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES WDT_SW                   //No Watch Dog Timer, enabled in Software
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES NOSTVREN                 //Stack full/underflow will not cause reset
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock=64M)
main(){
 setup_oscillator(OSC_64MHZ|OSC_INTRC|OSC_PLL_OFF);
But no work the timer1, i think that no runnig to 64M
#int_TIMER1
void TIMER1_isr(void){                         //
   cont++;                                          //
   if(cont == 2){                                 // 0,5*1=1 seg
        ban_1seg = 1;cont = 0;
   set_timer1(-934464);                               // 0.5=4/64000000*8(65536-x),x=-934464
Thank!
PostPosted: Sun Apr 05, 2015 2:28 am     Reply with quote
First, you are turning it off......
There is not a 64MHz 'oscillator' internally. The fastest is the 16Mhz oscillator, _which you can then run with the PLL, to give 64MHz_...
You are deliberately turning the PLL off!....
What does OSC_PLL_OFF do?.
Then, your 'main' code will run off the end, and stop the chip.
Then you are not enabling the interrupt.
Then you are not setting up/starting the timer.
Then the timer is a 16bit timer. What makes you think it can be set to a value like -934464?.
You have a lot of problems.....
#include <18F26K22.h>
#use delay(clock=64M, internal=16MHz)
int8 cont=0;
int8 ban_1seg=0;
#define TICKS 15 //interrupt ticks for 0.5 seconds
#int_TIMER1
   static int8 internal=TICKS-1;
   if (internal)
      --internal;
      //Now this will be approximately 0.5 seconds
      internal=TICKS-1; //reset counter
      cont++;                                          //
      if(cont == 2)
      {                                 // 0,5*1=1 seg
         ban_1seg = 1;
         cont = 0;
   setup_oscillator(OSC_64MHZ | OSC_INTRC);
   //Now the _slowest_ timer1 can run from a 64MHz clock, is 64000000/(4*8*65536) = 30.5 interrupts/second...
   setup_timer1(T1_INTERNAL | T1_DIV_BY_8);
   enable_interrupts(GLOBAL); //enable the interrupt
   do
   } while (TRUE); //and leave the chip running waiting for interrupts
cvargcal
PostPosted: Sun Apr 05, 2015 9:59 am     Reply with quote
int8 cont=0;
int8 ban_1seg=0;
#int_TIMER1
   if (internal)
      --internal;
      cont++;                                          //
      if(cont == 2)
      {                                 // 0,5*1=1 seg
         ban_1seg = 1;
         cont = 0;
   do
Yes, i have many problems xD
Ok, Thank
I say 64MH because in PIC18F26K22.h
is:
#define OSC_PLL_ON  0x4000
#define OSC_PLL_OFF 0
#define OSC_31250   0x8000
#define OSC_31KHZ   0x00
#define OSC_250KHZ  0x10
#define OSC_500KHZ  0x20
#define OSC_1MHZ    0x30
#define OSC_2MHZ    0x40
#define OSC_4MHZ    0x50
#define OSC_8MHZ    0x60
#define OSC_16MHZ   0x70
#define OSC_32MHZ   0x4060
#define OSC_64MHZ   0x4070
and the timer is with this formule :0.5=4/64000000*8(65536-x),x=-934464
;) Thank! my my knowledge is little.
The code work, but please do you can say how work?
Why #define TICKS 15?
why you no used set_timer1()?
PostPosted: Sun Apr 05, 2015 10:56 am     Reply with quote
Yes, I'm being a 'pedant'. Smile
However it is important to understand that you run with a 16MHz oscillator, and a 64MHz clock.
Little details like this are vital when dealing with chips.
Being pedantic, several of the standard CCS nomenclatures are 'dubious'. It's like "#use RS232", which actually controls the generation of TTL async serial, _not_ 'RS232'. This can be used with a whole variety of different signalling standards (RS232, RS485 etc..), but can't actually generate 'RS232' without external hardware. It's little details like this that encourage getting 'the wrong idea' about what chips can actually do!....
cvargcal
PostPosted: Sun Apr 05, 2015 11:13 am     Reply with quote
Thank master, now undertand that on thing is oscillador and other is clock.
Do you think that is better used external oscillator to internal?
My other questions is.
I used this for timer1 (with 4MHZ work perfect)
#int_TIMER1
   cont++;                                          //
   if(cont == 2){                                  // 0,5*2=1 segundo
        ban_1seg = 1;cont = 0;              //
   set_timer1(3036);                     // 0.5=4/4000000*8(65536-x),x=3036 >> Tiempo de desbordamiento es 0.5 segundos
and
void main(){
//-------------- Configuración ----------           //
     setup_timer_1 (T1_INTERNAL | T1_DIV_BY_8);     // Configuración  Timer1
     set_timer1 (3036);                             // 0.5=4/4000000*8(65536-x),x=3036 >> Tiempo de desbordamiento es 0.5 segundos
     enable_interrupts(int_timer1);                // Deshabilitar Interrupción timer1
     enable_interrupts(GLOBAL);                     // Habilitar Interrupción Global
     Reset();
     enable_interrupts(int_timer1);                 // Habilitar Interrupción Timer1
//--------------- Subprograma ---------------
   while(true){
                if(ban_1seg){                                    //
                  ban_1seg = 0; seg++;                     //
                  if(seg == 60){                                 // Si ya van 60 seg
                      seg=0;min++;                            //
                      if (min==6){                              //
                        min=0;                                    //
                        disable_interrupts(int_timer1); Reset(); //
I no undertand your code
int8 cont=0;
int8 ban_1seg=0;
#int_TIMER1
   if (internal)
      --internal;
      cont++;                                          //
      if(cont == 2)
      {                                 // 0,5*2=1 seg
         ban_1seg = 1;
         cont = 0;
Why 15?
Thank so much!
