simulation problem
slyman
simulation problem
PostPosted: Thu Apr 02, 2015 2:33 pm     Reply with quote
Hi everyone,
I'm trying to simulate my code in isis. When I simulate it's not work as I expect. My friend send his design, it's working well. I created same design it's still dosen't work.
So please help me. My midterm exam is coming and I don't know what to do
#include <16f877.h>
#fuses   XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=4000000)
#use fast_io(b)
int i;
#int_ext
void ext_kesmesi()
   output_high(pin_b1);
   output_low(pin_b1);
   delay_ms(3000);
   for (i=0;i<10;i++)
      output_low(pin_b1);
   set_tris_b(0x01);
   output_b(0x00);
   ext_int_edge(H_TO_L);
   enable_interrupts(INT_EXT);
Sam_40
PostPosted: Thu Apr 02, 2015 2:59 pm     Reply with quote
I have the answer for your question! would you please visit this link:
http://www.ccsinfo.com/forum/viewtopic.php?t=47549
slyman
PostPosted: Thu Apr 02, 2015 3:03 pm     Reply with quote
I new saw that. I wouldn't ask if it isn't urgent.
and I am sorry
Sam_40
PostPosted: Thu Apr 02, 2015 3:10 pm     Reply with quote
Try this:
#include <16f877.h>
#use fast_io(b)
void ext_kesmesi()
   int i;        /* Keep your vriable local as much as you can */
      output_low(pin_b1);
      delay_ms(3000);
      for (i=0;i<10;i++)
            output_low(pin_b1);
   while(true)
      ext_kesmesi() ;
slyman
PostPosted: Thu Apr 02, 2015 3:20 pm     Reply with quote
I was making changes in lines. I delete #use fast_io(b) and it worked.
Can anyone explain why ?
Sam_40
PostPosted: Thu Apr 02, 2015 3:24 pm     Reply with quote
My bad, The CCS manual stated
"#USE FAST_IO(port) This directive will configure the I/O port to use the fast method of performing I/O.
The user will be responsible for setting the port direction register using the
set_tris_x() function."
slyman
PostPosted: Thu Apr 02, 2015 3:48 pm     Reply with quote
Thank you for reply. I will be more careful and follow the rules Smile
Sam_40
PostPosted: Thu Apr 02, 2015 3:50 pm     Reply with quote
You are welcome,
