Jody
i2c problem with CAP1298 |
Posted: Tue Mar 31, 2015 7:01 am |
What I have:
- Compiler 4.119
- PIC18F87J50
- CAP1298
I have the pin 65 SDA connectect to the pin 2 SMDATA, with pull-up,
pin 64 SCL connected to the pin 3 SMCLK olso with pull-up.
What I want to do at this moment is to see that I have a connection to the CAP1298 chip.
I send the address and the register address what I want to read back and read the data. I get alway 255.. included mine code.. where o where am I missing the point??
main.c:
#include <main.h>
#include <CAP1298.h>
// _ __ ___ __ _(_)_ __ / / \ \
// | '_ ` _ \ / _` | | '_ \ | | | |
// | | | | | | (_| | | | | | | | | |
// |_| |_| |_|\__,_|_|_| |_| | | | |
// \_\ /_/
setup_adc_ports(sAN15);
CAP_init();
main.h:
#include <18F87J50.h>
#device ICD=TRUE
#device adc=16
#use delay(clock=40000000)
#use i2c(Master,sda=PIN_D5,scl=PIN_D6,I2C2,SMBUS,FORCE_HW)
#define CAPxxxx_ADDRESS 0b01010000
#define CAPxxxx_ID 0x71
CAP1298.h:
void CAP_init(void)
int16 value = 0;
i2c_start();
i2c_write(CAPxxxx_ADDRESS);
i2c_write(0xFD); // addres waar device id moet staan
delay_us(10);
value =i2c_read();
i2c_stop();
delay_us(1);
drh
Joined: 12 Jul 2004 Posts: 193 Location: Hemet, California USA
Posted: Tue Mar 31, 2015 7:48 am |
Table 3.3 shows you what to do.
You need to restart after you send the register address, then read. _________________ David |
Posted: Tue Mar 31, 2015 7:55 am |
You are not handling the I2C right.
The device address is 0101 000R The 'R' is '1' for reading, and '0' for writing. When you talk to an I2C device the sequence is:
For write:
start
send write address
send register address
send data
send stop
For read:
start
send write address
send second start (restart)
send read address
read data (nack the last byte)
send stop
Table 3-6 in the data sheet.
I see Drh pointed the same thing out while I was typing.  |
Jody
Posted: Tue Mar 31, 2015 8:09 am |
Thanks for the info!!!
I am still getting nothing.... (I am still not doing it right)
I have tried:
void CAP_init(void)
int16 value = 0;
// Verify the CAPxxxx's Device ID
i2c_start();
i2c_write(0b0101000);
i2c_start();
i2c_write(0b0101001);
value = i2c_read();
i2c_stop();
delay_us(1);
Jody
Posted: Tue Mar 31, 2015 8:40 am |
Hi I have made some progress!!!!
After programming it works!!!!
only once....
If I asked the value again it get stuck in the i2c_start() routine..
Maybe a reset or so??
#define CAP_ADDRESS_write 0b01010000
#define CAP_ADDRESS_read 0b01010001
void CAP_init(void)
int16 value = 0;
i2c_start();
i2c_write(CAP_ADDRESS_write);
i2c_start();
i2c_write(CAP_ADDRESS_read);
value = i2c_read();
i2c_stop();
delay_us(1);
Regards,
Jody |
Posted: Tue Mar 31, 2015 12:33 pm |
Study the read code that Ttelmah posted. Compare it to your code.
Make sure you read about the function parameters for i2c_read().
Quote: | For read:
start
send write address
send read address
send stop |
Joined: 01 Jul 2010 Posts: 9503 Location: Greensville,Ontario
Posted: Tue Mar 31, 2015 3:20 pm |
hmm... i2C device...
What are the I2C bus pullup resistor values ?
Jody
Posted: Tue Mar 31, 2015 3:33 pm |
Yes Ttelmah and Drh you where right.....
i2c_start();
i2c_start();
value = i2c_read();
value1 = i2c_read();
i2c_stop();
Did solved I has to read more accurate.. it was all there...
Thanks for the assistance!! It pointed me in the right direction!!
Pull-ups are 4k7.
Regards,
Jody |
Posted: Tue Mar 31, 2015 11:02 pm |
Jody wrote: |
i2c_start();
i2c_start();
value = i2c_read();
i2c_stop();
The CAP1298 data sheet doesn't say to do it that way. Look at Table 3.6
(on page 17): http://ww1.microchip.com/downloads/en/DeviceDoc/00001571A.pdf
Quote: | Table 3.6 Block Read Protocol
The data sheet says you should do it this way, when reading a block
of bytes (ie., two or more bytes):
i2c_start();
i2c_write(0xFD); // Register address for Product ID
i2c_start();
value = i2c_read();
value1 = i2c_read(0); // Must do a NACK on the last read
i2c_stop();
Jody
Posted: Wed Apr 01, 2015 12:49 am |
Yes you are right!!
I tested it and it works!!
Again: I have to read the datasheet more accurate!
Thanks for the assistance!!!
Regards,
Jody |
