PIC18F4550+ENC28J60
bbassem
PIC18F4550+ENC28J60
PostPosted: Sun Mar 29, 2015 8:25 am     Reply with quote
Hi, I'm working in web server project using PIC 18f4550 + ENC28j60. I found 2 examples. I tested them to know the working principle of the TCP / IP stack, but it doesn't work. I've looked for a solution from many forums but I didn't found any solution. Can anyone help me please.
(Sorry for my bad english).
jgschmidt
PostPosted: Tue Mar 31, 2015 10:42 am     Reply with quote
I recommend you perform searches for TCP/IP and for ENC28J60 in this forum. This issue has been discussed here many times.
Jürgen
www.jgscraft.com
asmallri
Re: PIC18F4550+ENC28J60
PostPosted: Wed Apr 01, 2015 7:45 pm     Reply with quote
This is not a very good combination. The ENC28J60 is a basic Etherent controller. It does not implement any higher layer networking functions like IP, UDP, TCP and everything else that rides on top of this. When using this Ethernet controller the PIC has to implement the TCP/IP stack and your application.
The PIC18F4550 has only 32K of program memory and only 2K of RAM. You will struggle to implement any useful Web application on it. That is the reason Microchip's PIC18F97J60 family of micro controllers with embedded Ethernet controllers have significantly more program memory and RAM.
Regards, Andrew
bkamen
PostPosted: Thu Apr 02, 2015 8:35 am     Reply with quote
[quote="asmallri"]
Not to mention an 8K buffer exclusive to the Ethernet MAC.
So in addition to their 4K of general purpose RAM, they have 8K of RAM hiding in the MAC to handle buffering transmit and receiver packets.
however, the ENC28j60 also has an ethernet buffer. (but it needs to be pushed around over the SPI port. Slooooooowwww)
I would also say to stick to the PIC18F ethernet pics. You can do more with them.
ezflyr
PostPosted: Thu Apr 02, 2015 8:42 am     Reply with quote
Also, I'd be willing to bet that this request has nothing whatsoever to do with CCS C!
John
