FAT32 MMC SD (the new old topic)
farouk_baya
PostPosted: Tue Mar 24, 2015 10:09 am     Reply with quote
Hello;
I'm working in a project with MMC SD and I use the ex_fat.c file but the simulation in isis doesn't work.
The used schematic is as follows:
[img]http://www.4shared.com/download/eKD2rbQcce/test_isis.png?lgfp=3000[/img]
the code is as follows:
////                     fat_ex_shell.c                              ////
////    This is a neat little shell utility that resembles a DOS or  ////
//// UNIX type shell in order to manipulate files on the FAT file    ////
//// system. This is mostly for demonstration purposes on how to use ////
//// some of the basic functionality of the FAT library.             ////
////        (C) Copyright 2007 Custom Computer Services              ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
//These settings are for the CCS PICEEC development kit which contains
//an MMC/SD connector.
#include <18F4620.h>
#device PASS_STRINGS = IN_RAM
#fuses NOWDT, HS, NOPROTECT
#use delay(clock=25M)
Ex_fat.c code mostly removed.
Reason: Forum rule #10:
10. Don't post the CCS example code or drivers
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
- Forum Moderator
Is there any recommendation.
PostPosted: Tue Mar 24, 2015 11:16 am     Reply with quote
It's been quiet for a while with SD card questions and now 3 people in the same day. Must be a new student assignment that has started.
Your circuit is wrong. See the answer posted by Ttelmah in one of the other threads today: http://www.ccsinfo.com/forum/viewtopic.php?t=53692
ELCouz
PostPosted: Wed Mar 25, 2015 10:26 am     Reply with quote
Also ISIS is NOT SUPPORTED in this forum.
Read the FAQ...
http://www.ccsinfo.com/forum/viewtopic.php?t=47549
Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
PostPosted: Wed Mar 25, 2015 1:29 pm     Reply with quote
Of course it doesn't 'work' in ISIS...
ISIS aka Proteus is NOT a WORKING simulator....
also no one here will rewrite the ISIS simulator to get it TO work...
If I had a penny for every ISIS problem posted , I could BUY CCS !!
Jay
