Help for PIC18F67K22 and LCD driver HDM64GS12.C
MegatroniC
View user's profile Send private message ICQ Number
PostPosted: Thu Mar 12, 2015 12:44 am     Reply with quote
Hello all.
I hope you can help me on this problem.
Display works without problems in the simulation.
http://s2.postimg.org/70t7onhqh/problem.jpg
But does not work in the real PCB. :(
Maybe not initialize because all voltages in the display are available.
Sometimes backlight only lights up, and sometimes displayed pixels randomly.
I have never encountered this in other chips, such as 18F4620, 18F46K22 ...
Here configuration:
HDM64GS12.C
#ifndef HDM64GS12
#define HDM64GS12
#ifndef GLCD_WIDTH
#define GLCD_WIDTH   128
#endif
#ifndef GLCD_CS1
#define GLCD_CS1     PIN_E3   // Chip Selection 1
#endif
#ifndef GLCD_CS2
#define GLCD_CS2     PIN_E4   // Chip Selection 2
#endif
#ifndef GLCD_DI
#define GLCD_DI      PIN_E5   // Data or Instruction input - RS pin
#endif
#ifndef GLCD_RW
#define GLCD_RW      PIN_E6   // Read/Write
#endif
#ifndef GLCD_E
#define GLCD_E       PIN_E7   // Enable
#endif
//#ifndef GLCD_DIT
//#define GLCD_DIT     PIN_C0   // Reset
//#endif
test.h
#include <18F67K22.h>
#FUSES WDT                      //Watch Dog Timer
#FUSES WDT1024                  //Watch Dog Timer uses 1:1024 Postscale ->4.096s
#FUSES SOSC_DIG                 //Digital mode, I/O port functionality of RC0 and RC1
#FUSES NOXINST               //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES HSH                      //High speed Osc, high power 16MHz-25MHz
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES PUT                      //Power Up Timer
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES WDT_NOSLEEP              //Watch Dog Timer, disabled during SLEEP
#FUSES PROTECT                  //Code protected from reads
#FUSES NOWRTD
#use delay(int=16000000,RESTART_WDT)
test.c
 gc_old_switch_status = read_switches();        // Read and save the initial state of the switches
 setup_timer_0(RTCC_INTERNAL|RTCC_DIV_64);   //1.0 s overflow
 setup_timer_1(T1_INTERNAL|T1_DIV_BY_2);     //32.7 ms overflow
 //setup_timer_2(T2_DIV_BY_16,250,10);         //1.0 ms overflow, 10.0 ms interrupt
 setup_timer_2(T2_DIV_BY_16,250,15);         //1.0 ms overflow, 15.0 ms interrupt
 setup_timer_3(T3_DISABLED);
 setup_timer_5(T5_DISABLED);
 setup_timer_6(T6_DISABLED,0,1);
 setup_timer_7(T7_DISABLED);
 setup_timer_8(T8_DISABLED,0,1);
 setup_timer_10(T10_DISABLED,0,1);
 setup_timer_12(T12_DISABLED,0,1);
 setup_rtc(RTC_DISABLE);
 setup_psp(PSP_DISABLED);
 setup_spi(SPI_DISABLED);
 //setup_uart(FALSE);
 setup_adc(ADC_OFF);
 setup_adc_ports(NO_ANALOGS);
 setup_ccp1(CCP_OFF);
 setup_ccp2(CCP_OFF);
 setup_ccp3(CCP_OFF);
 setup_ccp4(CCP_OFF);
 setup_ccp5(CCP_OFF);
 setup_ccp6(CCP_OFF);
 setup_ccp7(CCP_OFF);
 setup_ccp8(CCP_OFF);
 setup_ccp9(CCP_OFF);
 setup_ccp10(CCP_OFF);
 setup_vref(FALSE);
 //ODCON1=0x00;    //Open-drain capability is disabled
 //ODCON2=0x00;
 //ODCON3=0x00;
 //port_d_pullups(0xFF);
 //port_e_pullups(0xFF);
 set_tris_a(0xBF);
 set_tris_b(0x3F);
 set_tris_c(0x00);
 set_tris_e(0x00);
 set_tris_f(0x00);
 set_tris_g(0x00);
 output_c(0x00);
 glcd_init(ON);
 ReadStoreValue();
Perhaps I'm wrong settings for port D and port E ...
PostPosted: Thu Mar 12, 2015 1:00 am     Reply with quote
Your schematic doesn't show any connections to the LCD on pins 4 and 5,
which are Vdd and contrast.
Your Proteus schematic doesn't even show a connection for the backlight.
Post a schematic of your real hardware connections.
MegatroniC
PostPosted: Thu Mar 12, 2015 1:21 am     Reply with quote
PIC
http://s14.postimg.org/m12faum9t/Clipboard02.jpg
LCD
http://s14.postimg.org/6gv1kbc5d/Clipboard04.jpg
V0 ~ 5,6V
VEE ~ 9,4V
This scheme for display use often without problems.
But this PIC I use for the first time.
PostPosted: Thu Mar 12, 2015 1:22 am     Reply with quote
He is also setting the clock to use both the internal oscillator, and an external crystal....
The real chip needs the oscillator setup correctly.
MegatroniC
PostPosted: Thu Mar 12, 2015 2:25 am     Reply with quote
HSH -> #FUSES INTRC_IO //Internal RC Osc, no CLKOUT ?
The rest of the program works correctly, only the display does not work.
MegatroniC
PostPosted: Thu Mar 12, 2015 3:29 am     Reply with quote
I tried
output_d(0xFF);
output_e(0xFF);
and removing the initialization for LCD.
only RE5(RS for LCD) and RE7(E for LCD) stay at 0.
probably this is the reason for the problem, but why?
MegatroniC
PostPosted: Thu Mar 12, 2015 3:51 am     Reply with quote
Problem is solved!
With new 67К22. Very Happy
Perhaps a manufacturing defect or soldering ...
Good Day to all!
PostPosted: Thu Mar 12, 2015 8:53 am     Reply with quote
You are just being lucky.....
HSH, is the fuse for High speed crystal/resonator, running in high power mode.
It is being overriden by your clock setting, and luckily happens to hit a combination that works. INTRC_IO is the fuse for internal RC oscillator no CLKOUT.
Look at the file 'fuses.txt' in your compiler directory, to find what each fuse 'name' does.
