stepper motor for loop
Goto page 1, 2  Next
zeyad
PostPosted: Mon Mar 02, 2015 9:52 pm     Reply with quote
#include <18f6723.h>
#fuses   HS,NOLVP,NOWDT,NOPROTECT
#use     delay(clock=20M)
//int16 table[4]={3,6,12,9};
int8 ax[4]={9,12,6,3};
void s1(unsigned int rev)
int j;
int i=0;
for(i=0;i<(rev*360/1.8);i++){
  output_b(ax[i%4]);
  for (j=1000;j<50;j--){
    delay_ms(j);
//setup_adc_ports(NO_ANALOGS);
//set_tris_c(0xff);
//set_tris_b(0x00);
do{
s1(1);
}while(true);
My stepper motor is not rotating more than 1.8 degrees. What i want to do is to gradually ramp up the stepper motor. Please help.
PostPosted: Mon Mar 02, 2015 10:56 pm     Reply with quote
ckielstra told you not to use 'short' in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=53579&start=4
But you are still doing it here:
void s1(unsigned short rev)
int16 j;
int16 i=0;
We expect you to read everything we say, and fix every problem.
zeyad
thnx
PostPosted: Tue Mar 03, 2015 5:25 am     Reply with quote
int16 j;
int16 i=0;
zeyad
still didn't work
PostPosted: Tue Mar 03, 2015 5:33 am     Reply with quote
int16 j;
int16 i=0;
Mike Walne
PostPosted: Tue Mar 03, 2015 6:10 am     Reply with quote
Your code is neither complete nor compilable.
You do not have a main().
Follow the instructions/advice given in previous threads.
Read the forum guidelines.
Mike
PostPosted: Tue Mar 03, 2015 8:26 am     Reply with quote
this...
int16 ax[4]={9,12,6,3};
seems 'silly' to me as
1) the data are not 16 bit values
I am 'assuming' the 3,6,12,9 would be better shown as binary ( bits) to visually show others the 'stepper motor' control signals. I'd probably use unsigned int8 or char. Char is the same as unsigned int8 but I always think of it a 0-255 as 'int' to me is -127 to +128.
2) one table could be used
This would save space, make coding easier,faster,etc. You can got 'forward' and 'reverse' using + or - in the index variable.
Also table[] and ax[] really do not say WHAT the data is for. CCS C allows you to name them with 'real' names like 'stepping_motor_drive_sequence' or something shorter, similar. It's really help you and others debug when you name variables with their intended use...
Jay
jgschmidt
Stepper speed ramp up and down
PostPosted: Tue Mar 03, 2015 2:29 pm     Reply with quote
I use bipolar stepper motors and save a lot of headaches by using driver boards such as you can get from Sparkfun and Pololu. These usually accept three inputs such as Enable, Step and Direction. A typical routine I use for ramping up and down is here:
unsigned int16 i, j, memLength  // globals - counters and desired total length of wire in .2" increments
void Feed( void )
  output_low( M1ENA );
  output_high( M1DIR );
  for( j=325L; j>240; j--){     // Speedup for 1 inch
    output_high( M1STP );
    delay_us( 1 );
    output_low( M1STP );
    delay_us( j*5 );
  for( j=0; j<memLength-10; j++) {
    for( i=0; i<17; i++ ) {     // 1/5 inch
      delay_us( 1 );
      delay_us( 1200 );
  for( j=240; j<325L; j++){     // slowdown for 1 inch
    delay_us( 1 );
    delay_us( j*5 );
  output_high( M1ENA );
I use this to feed wire off a large reel an have a little bit of a ramp to avoid jerking on the reel or slipping the wire in the feeder. The ideal step spacing for this particular motor is 1200 microseconds (us) between steps. To ramp up I start out with 1625 us per step and decrease that in a loop. When I slow down I just do the reverse. If you need a more gradual ramp just change the timing some more. I'm using the default 200 steps per rev, which was "good enough" for me. Some boards support up to 3200 steps per revolution, allowing for very detailed control and smooth ramping.
You can see this in action here: http://youtu.be/qVjijZRdiTA
Jürgen
www.jgscraft.com
zeyad
Re: Stepper speed ramp up and down
PostPosted: Wed Mar 04, 2015 4:12 am     Reply with quote
void Feed( void )
    delay_us( 1 );
    delay_us( j*5 );
      delay_us( 1 );
      delay_us( 1200 );
    delay_us( 1 );
    delay_us( j*5 );
thnx alot this helps me alot
zeyad
now see please
PostPosted: Wed Mar 04, 2015 4:25 am     Reply with quote
Mike
int j;
int i=0;
  output_b(ax[i%4]);
    delay_ms(j);
//set_tris_c(0xff);
//set_tris_b(0x00);
do{
s1(1);
}while(true);
zeyad
now see please
PostPosted: Wed Mar 04, 2015 4:26 am     Reply with quote
temtronic wrote:
this...
Jay
int j;
int i=0;
  output_b(ax[i%4]);
    delay_ms(j);
//set_tris_c(0xff);
//set_tris_b(0x00);
do{
s1(1);
}while(true);
stinky
PostPosted: Wed Mar 04, 2015 4:42 am     Reply with quote
Data type and order of operations
int j;
int i=0;
output_b(ax[i%4]);
delay_ms(j);
You're performing float math on an integer and are you sure your equation is doing what you intend?
PostPosted: Wed Mar 04, 2015 4:45 am     Reply with quote
You are still ignoring lots of things you have been told. I'll put some comments in part of your code, _read them_:
int j;
int i=0;
//rev *360, will overflow the maths being used as soon rev>1
  output_b(ax[i%4]);
//What is the biggest number that 'j' can hold?.
//Is the loop ever going to execute?. j is never '<50' so loop
//will exit immediately.
    delay_ms(j);
//If it did work, just how long is this going to take?. 1 step per second
//at the start!.....
Mike Walne
PostPosted: Wed Mar 04, 2015 9:39 am     Reply with quote
You're still making it difficult to help. So I'll use another tack.
Try this code and tell us what happens as you change the value for "t".
#include <18F6723.h>
#use     delay(clock=20000000)
int8 step[4]={0b1001,0b1100,0b0110,0b0011};
main()
   int8 t=50;
   int8 i;
   while (1)
      for (i=0 ; i <4 ; i++ )
         output_b(step[i]);
         delay_ms(t);
Mike
EDIT
You changed the code in your original post, after several responses.
That alters the logic of the thread and make it difficult to follow.
Your motor does 200 steps per rev, so why mess about with 360/1.8 floating point maths?
zeyad
reply
PostPosted: Wed Mar 04, 2015 10:27 pm     Reply with quote
main()
   int8 t=50;
   int8 i;
   while (1)
         output_b(step[i]);
         delay_ms(t);
Mike
EDIT
so that i can take the code to greater steps
zeyad
reply
PostPosted: Wed Mar 04, 2015 10:38 pm     Reply with quote
main()
   int8 t=50;
   int8 i;
   while (1)
         output_b(step[i]);
         delay_ms(t);
Mike
EDIT
when i change the value of t the motor speed increases or decreases corresponding to the delay
Goto page 1, 2  Next
Page 1 of 2
